@Paul (North) DC5 Brembos - Civinfo
Go Back   Civinfo > vendors > TDi North
Old 18th August 2011, 18:38   #1 (permalink)
Civinfo Hobbyist Trader
Loxy's Avatar
Car: 2009 Championship White FN2
Thanks given: 1,559
Thinking about some DC5 Brembos, well Acura TL Type S Brembos to be exact.
I can source the calipers, but will need pads, S2000 discs, spacers and your knowledge of what to do.
I would prefer to try Cosworth pads if they do them in the right size, DS2500/DS3000 if not.
I'm also thinking of a grooved disk instead of a standard one, so any suggestions?
I've been told you can use 5mm spacers on the OEM wheels with the Brembos, but I'm thinking 15mm will fill the arch better with the camber I'm running and they are about the same price aren't they? I would want front and rear for the looks if nothing else unless there is a reason why I shouldn't.
You can PM a price or post up, I'm not fussed about people knowing what I spend.
I'm thinking of going for this set-up over the Stoptech Touring kit, unless it ends up a similar price all in and/or you think that the Stoptech kit will be better round Nurburgring and Spa next spring.
I'm not really keen on spending 1500 on the full BBK though I know this will give the best results for the road trip, but might be overkill for the 95% of the time the car will spend on the road.
Some mates have been trying to talk me into the Spoon cailpers, but they seem mega considering they use the same pad and disc size. They can't be as good as the Brembos or Stoptechs can they?
Cheers in advance.
Loxy is offline   Reply With Quote Quick reply to this message
Old 18th August 2011, 22:43   #2 (permalink)
Smigzy's Avatar
Car: K20 EG Sleeper :)
Thanks given: 51
What you got on there at the minute John?
Smigzy is offline   Reply With Quote Quick reply to this message
Old 18th August 2011, 22:44   #3 (permalink)
DEZIBOY's Avatar
Car: 2009 CTR championship white
Thanks given: 765
Dustbin lids lol
DEZIBOY is offline   Reply With Quote Quick reply to this message
Old 18th August 2011, 22:47   #4 (permalink)
Aye Aye....
DPG87's Avatar
Car: 2009 CTR, Milano
Thanks given: 740
thought about that Silvers BBK from Mike at Bravura Speed?
mines is getting shipped o the 20th
DPG87 is offline   Reply With Quote Quick reply to this message
Old 18th August 2011, 22:51   #5 (permalink)
Smigzy's Avatar
Thanks given: 51
Personally id go for stoptech discs, ds3000's, RBF600 fluid and braided lines if you dont have them already. Brembo's are a slight upgrade but not on par with a BBK IMO
Old 18th August 2011, 23:28   #6 (permalink)
Loxy's Avatar
Thanks given: 1,559
I've got everything you've mentioned bar the Stoptech discs and I'm on DS2500s.
I do get good bite, but I've managed to get them to fade quite a bit since having the charger put on.
So you would rate the Brembos, Spoons and Stoptech Touring (300mm, slightly smaller 4pot than the full BBK) as roughly the same?
Looking at the full Stoptech BBK really then!
Old 19th August 2011, 07:17   #7 (permalink)
Commercial user
tdi-north's Avatar
Thanks given: 216
Im not to sure on requirements to be honest as not fitted the Brembos to an FN2.
Saw one come in last week though and it had spacers behind the discs to get them to sit central in the caliper which isn't great.
Problem is disc to pad area. Only the Brembos actually offer a bigger pad. Just applying more force will cause overheating of the pad and disc and create warping and fade if used in anger too much.
I used to have the Spoons with DBA rotors on my EP3. They looked good but still overheated with track use and are expensive for what they are plus it's jut the calipers you buy. You still need the brackets, lines, pads and rotors. Stoptech do work out really good value when you start to look at it that way.
Paul
tdi-north is offline   Reply With Quote Quick reply to this message
Old 19th August 2011, 10:32   #8 (permalink)
Loxy's Avatar
Thanks given: 1,559
Certainly does seem that is the case!
Bit more saving required then!
Old 19th August 2011, 11:47   #9 (permalink)
murray's Avatar
Car: CW Civic FD2
Thanks given: 159
I had the stoptechs on my old FN2, Done a few trackdays with them and a lot of days out driving around the Brecon Beacons in Wales. Never had any fade and worth their weight in gold. They may be a little overkill or driving to work and back. But it is nice to think that if you do need to do some extreme braking
murray is offline   Reply With Quote Quick reply to this message
Old 19th August 2011, 14:36   #10 (permalink)
翻訳中に失わ
Car: 2014 1.6 i-DTEC SR
Thanks given: 54
+1 on saving the extra for the Stoptech BBK they are awesome
Another thing to note is a 6kg weight saving on the Stoptech BBK over standard discs and calipers
CraigyM200 is offline   Reply With Quote Quick reply to this message
Old 19th August 2011, 14:57   #11 (permalink)
aka Colin
pigdog's Avatar
Car: 2008 CTR GT, Black
Thanks given: 922
Have you thought about D2 8 pots John, I've heard there pretty good and alot cheaper than the ones you've mentioned?
- Sent from my iPhone using Tapatalk
pigdog is offline   Reply With Quote Quick reply to this message
Old 19th August 2011, 15:04   #12 (permalink)
Loxy's Avatar
Thanks given: 1,559
Aye same as the K-sport ones. TerryH uses them.
Two concerns really.
How easy will it be getting hold of pads and discs since they aren't mainstream.
I've also not heard good things about D2 parts. Their camber arms for example for the EP3/DC5 are pretty poor by all accounts.
Old 19th August 2011, 15:08   #13 (permalink)
aka Colin
pigdog's Avatar
Thanks given: 922
Yes I think they're the same as the k sport mate, as for pads and discs I'm not sure. Was just throwing it out there as an option mate. If I had the money I'd just get the stoptechs but the big kit as I think the touring kit looks small.
Old 19th August 2011, 17:05   #14 (permalink)
R555's Avatar
Car: 2007 CTR, Milano Red
Thanks given: 837
Dont all these BBK kits use the same Porsche Pad size?
R555 is offline   Reply With Quote Quick reply to this message
Old 19th August 2011, 17:27   #15 (permalink)
F1le's Avatar
Car: 2010 FN2 CW K24/K20
Thanks given: 5
Yeah, for stoptech you can use almost all brands ENDLESS with EIP001 part number or even Project Mu with Z152 part number. Just need to take a look for specific Porsche pad shape. I'm not even mentioning about such common pads like DS2500 or HAWK. I'm mounting my ENDLESS pads with my stoptech tomorrow, and it was dedicated for Porsche, and it had the same pad shape as DS2500 dedicated for stoptech.
All my mods are only based on JDM manufacturers except brakes. These are STOPTECH BBK, because they got the best quality for price... and they are so good, that when I'm taking a friend for a ride and start to accelerate and later I had to brake from 200kmh (~125mph) he said "The acceleration is impressive, but how the car brakes is much more impressive..."
F1le is offline   Reply With Quote Quick reply to this message
Old 21st August 2011, 18:35   #16 (permalink)
Go Hard or Go Home!
civi08's Avatar
Car: BMW 335i M Sport
Thanks given: 165
cant praise the stoptech bbk enough to be honest, its an awesome bit of kit. takes time getting used to it, i was used to applying hard pressure to brake in time at speed with the oem setup. apply the same pressure with the bbk and u'll stop far too soon, theres no hint of spongyness at all and you slow down quick. well worth the price tag
civi08 is offline   Reply With Quote Quick reply to this message
Old 21st August 2011, 18:52   #17 (permalink)
Leepie's Avatar
Thanks given: 276
I've just received my k-sports and they look very well made. Pads are off the shelf (ds2500) and discs are 2 piece AP so no problems with availability. Being fitted on Wednesday so I will let you know.
Leepie is offline   Reply With Quote Quick reply to this message
Thanks to Leepie from:
Old 21st August 2011, 19:02   #18 (permalink)
Aye Aye....
DPG87's Avatar
Thanks given: 740
No thoughts on the Silvers Loxy? Lol
Old 21st August 2011, 19:18   #19 (permalink)
Loxy's Avatar
Thanks given: 1,559
I'm waiting for your opinions on them!
I'm all for people bringing out new products and I don't want to seem over critical because you've ordered them, but they just don't seem all that to me. I mean they look well made in the pics but they are dearer than the D2/K-Sport ones that I would consider if not going for a big name make.
Plus would you buy brakes from this man?
Old 21st August 2011, 19:25   #20 (permalink)
Aye Aye....
DPG87's Avatar
Thanks given: 740
LOL the chicks no bad tho lol
I think they look good, the spec is the same as the stoptech BBK so just need to see if they perform as well, but they are 500 cheaper so if they are just as good or there abouts it's a good price, I'll let you know in due course
Thanks to DPG87 from:
Insurance
Similar Threads for: @Paul (North) DC5 Brembos
Brakes Brembos on FN2 stuk20a2 Wheels, Tyres, Suspension and Brakes (8G) 5 26th March 2011 22:14
Brakes Evo Brembos on FN2 onweed Wheels, Tyres, Suspension and Brakes (8G) 17 2nd March 2011 00:17
Fast Road Setup - Thanks Paul and gang TDI North nickh2007 TDi North 21 2nd December 2010 19:38
Fao of Paul at Tdi north! doogle TDi North 2 16th November 2010 19:23
FAO Paul @Tdi North summ0004 TDi North 8 6th November 2010 15:06
» Premium Vendor Showcase
» Recent Discussions
The "What did you do to...
5th November 2011 19:40
by robbo51
Last post by lightningslow
Today 04:13
2 Replies, 139,257 Views
Honda Civic 5door wheel...
31st August 2019 20:05
Last post by balleballe
Today 02:56
6 Replies, 194 Views
Sunroof seal issue
27th June 2019 20:12
by rusky
Last post by M8TJT
Yesterday 23:29
6 Replies, 280 Views
Red Arrow FN2
10th May 2019 19:42
Last post by Mugen_fd2
Yesterday 21:18
63 Replies, 2,201 Views
Does any of this need...
12th September 2019 22:57
by Janny
Last post by Janny
Yesterday 21:14
6 Replies, 150 Views
Replace rear Disks and...
21st December 2015 15:25
by Sprotty
Last post by nturnb
Yesterday 20:46
47 Replies, 8,080 Views
1.6 diesel 6 monthly...
29th August 2019 09:04
Last post by nturnb
Yesterday 20:09
29 Replies, 700 Views
Parking Sensors
26th March 2017 22:40
Last post by Telboy
Yesterday 19:58
243 Replies, 23,308 Views
Bare metal at rear inner...
14th September 2019 15:11
by Riko
Last post by M8TJT
Yesterday 19:43
10 Replies, 162 Views
Fuel gauge stuck on empty
11th September 2019 17:29
by paulbes
Last post by M8TJT
Yesterday 19:06
14 Replies, 190 Views
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
