Slowing down too much when letting off Gas - Civinfo
post #1 of 16 (permalink) Old 7th February 2016, 12:17 Thread Starter
Noticed a lot of times when I take my foot of the gas the car seems to act like I'm lightly applying the brake - feels a bit like engine breaking, I noticed it in 5th gear when taking my foot off.
Issue with induction maybe or braking system, something catching?
Might be perfectly normal with the fn2 I'm not sure
Cheers
GoonstaSteve is offline
post #2 of 16 (permalink) Old 7th February 2016, 12:32
JSOCK's Avatar
Car: 2008 CTR Milano
Brakes could be binding, pretty common, especially the front calipers. Rebuild kits available on the bay cheap enough.
JSOCK is offline
post #3 of 16 (permalink) Old 7th February 2016, 12:34
JSOCK's Avatar
Have a feel of your discs/wheels after a drive, if any of them is warmer than it should be, that could be the culprit.
JSOCK is offline
post #4 of 16 (permalink) Old 7th February 2016, 12:34
CAM320N's Avatar
Car: 2010 CTS GT Black
Try going into neutral whilst moving see if it does it then.. If so as above brakes could be binding
CAM320N is offline
post #5 of 16 (permalink) Old 7th February 2016, 12:35
Whistlin' on a Tuesday...
moonlight168's Avatar
Car: 2015 1.6 I-DTEC SE+ Tourer
You may well have a bit of brake-binding on one or more wheels.
Try jacking up each corner and spinning the wheel to check. A tiny bit of rubbing with little or no resistance is fine, but if it is binding and difficult to turn by hand, the pads are binding on, probably because the runners are corroded...
moonlight168 is offline
post #6 of 16 (permalink) Old 7th February 2016, 13:22 Thread Starter
Ok cheers everyone will check everything out.
post #7 of 16 (permalink) Old 7th February 2016, 15:22
Vyse's Avatar
The FN2 has a lot of engine breaking due to the light flywheel I say its normal. Most noticeable in 1st, 2nd, 3rd and 4th.
Vyse is offline
Thanks to Vyse from:
post #8 of 16 (permalink) Old 7th February 2016, 15:56
retroppuS
MarBras's Avatar
Car: 2007 CTR FN2, Milano Red
+1 to this.
MarBras is offline
post #9 of 16 (permalink) Old 7th February 2016, 16:04
FireBIade's Avatar
Car: M200, er.....CW
Has the car been tuned? Could be the fuel cut a bit too aggressive.
FireBIade is offline
post #10 of 16 (permalink) Old 7th February 2016, 19:16 Thread Starter
Don't think it has ever been tuned before. I have no idea to be honest, everything seems standard on the car. It wasn't doing it previously though which makes me think it could be a brake issue or something else.
post #11 of 16 (permalink) Old 9th February 2016, 20:46
smokeydog's Avatar
just an a heads up please dont actually touch the disc it will be hot under normal conditions if the calipers sticking its going to be ow town
smokeydog is offline
Thanks to smokeydog from:
post #12 of 16 (permalink) Old 9th February 2016, 21:10
JSOCK's Avatar
Obviously dont just grab the disc, lick your finger and quickly touch it, it shouldnt sizzle after normal driving, you will be able to feel the heat radiating from the disc and wheel if its binding anyway.
JSOCK is offline
post #13 of 16 (permalink) Old 9th February 2016, 21:43
CAM320N's Avatar
Pmsl no more index finger
CAM320N is offline
post #14 of 16 (permalink) Old 9th February 2016, 21:55
Enjoying life
flashy's Avatar
Pretty obvious discs get very hot, not sure why anyone would want to touch them. +1 for checking the brakes out - I had a sticking brake piston and the wheel was noticeably warmer than the rest.
flashy is offline
post #15 of 16 (permalink) Old 9th February 2016, 22:54
Steven1976's Avatar
Car: 2009 CTR GT Milano Red
Send a message via MSN to Steven1976
I had the same issue and had to rebuild the front two caliper's, new seals and pistons
Steven1976 is offline
post #16 of 16 (permalink) Old 10th February 2016, 17:15 Thread Starter
Back brakes are basically cold after a long journey and front hot.
Also noticed like a whining noise or a noise like you slightly have your handbrake on when pulling away. Think it may be the rear discs or it might be the clutch.
Must say the transition going from ep3 to fn3 has made me paranoid haha.
Engine Winding noise when slowing down russman777 Bugs, faults and irritations (8G) 1 15th July 2013 23:16
I'm letting this guy wash my car! RobertUtley Cleaning 1 2nd March 2013 11:44
Clutch Shudder when letting out clutch matty0705 Engines and Transmission (8G) 4 7th June 2012 14:59
Whining noise when slowing down owls121 Type-R 12 13th June 2011 15:25
