P2646 HONDA VTEC Oil Pressure Switch Circuit Low Voltage, after FD2 oil pump instaled - Civinfo
 1Likes
  • 1 Post By Loxy
post #1 of 18 (permalink) Old 7th March 2016, 12:11 Thread Starter
goa_party's Avatar
Car: 2008 FN2 CTR, DeepBronze
Cool P2646 HONDA VTEC Oil Pressure Switch Circuit Low Voltage, after FD2 oil pump instaled
Hello guys,
I have installed the FD2 oil pump in my FN2 along wiyth spoon Baffle sump, the problem si now in full acceleration the engine gas is cut-off, the check engine lights on the dashboard along with VSA, and it's cutting the fuel at 4k rpm.
The only error is this:
And yes, the oil level is right.
Any idea what my cause this?
Thanks!
goa_party is offline
post #2 of 18 (permalink) Old 7th March 2016, 12:17
Typersam1's Avatar
Was the sump in good condition? as it sounds like it's being starved of oil somehow....I've not fitted one yet but do you need to prime the pump with oil before instillation or anything as does seem very strange
Typersam1 is offline
post #3 of 18 (permalink) Old 7th March 2016, 12:22 Thread Starter
goa_party's Avatar
Exclamation
The pump and sump are NEW!
post #4 of 18 (permalink) Old 7th March 2016, 12:43
Typersam1's Avatar
Just digging and found this .....
Reset the ECM first. If the code comes back check for continuity in the oil pressure switch with the ignition off. No continuity= replace the oil pressure switch. Check for resistance between the VTEC solenoid and body ground. Resistance should be 14-30 Ohms. If it isn't replace the VTEC
Hope this helps a bit pal
post #5 of 18 (permalink) Old 7th March 2016, 17:16
Car: FN2
did you plug the hole when you fitted the pump?
ghost_bhp is offline
Thank You to ghost_bhp from 2 Users:
post #6 of 18 (permalink) Old 7th March 2016, 17:38
Typersam1's Avatar
Haven't fitted to mine yet pal
post #7 of 18 (permalink) Old 7th March 2016, 20:20
Typersam1's Avatar
Soz ,ate wasn't reading properly lol ...good point tho
post #8 of 18 (permalink) Old 7th March 2016, 20:35 Thread Starter
goa_party's Avatar
what hole?
post #9 of 18 (permalink) Old 8th March 2016, 13:19 Thread Starter
goa_party's Avatar
Found the problem, I did not knew about the oil jet plug (between the two vacant bolt holes) that needs to be removed. When installing a K20 oil pump it's important this is blocked off otherwise it can lead to a big drop in oil pressure.
post #10 of 18 (permalink) Old 8th March 2016, 20:17 Thread Starter
goa_party's Avatar
http://www.civinfo.com/forum/engines...t-fn2-how.html
post #11 of 18 (permalink) Old 9th March 2016, 03:38
Car: FN2
Thats the one.
post #12 of 18 (permalink) Old 9th March 2016, 05:15 Thread Starter
goa_party's Avatar
Thats the one.
Feeling really frustrated, fixed the plug, accordingly, still the car fails the VTEC Test.
post #13 of 18 (permalink) Old 15th March 2016, 00:07
Clutch pedal guru
hondacivicnut's Avatar
Check the oil pressure. There's no way I'd be trying to 'VTEC' it after you've missed plugging an oil gallery. Has there been any engine damage due to the ommission of the plug?
hondacivicnut is offline
post #14 of 18 (permalink) Old 15th March 2016, 04:42
Car: FN2
Tear the motor apart and see if anything has melted
post #15 of 18 (permalink) Old 28th April 2016, 19:52
Any update to this, I have the same error. Also have VSA light on. Happened while driving along thr M6
Sn809 is offline
post #16 of 18 (permalink) Old 30th April 2016, 19:46
Car: FN2
who fitted your pump/
post #17 of 18 (permalink) Old 30th April 2016, 19:58
Civinfo Hobbyist Trader
Loxy's Avatar
Car: 2009 Championship White FN2
^This.
Take it straight back to whoever fitted the pump!
Farqui likes this.
Loxy is offline
post #18 of 18 (permalink) Old 1st May 2016, 13:25
Sorry, my bad. I have not had the pump replaced only the VTEC Oil Pressure Switch Circuit sensor changed, but that has not resolved the issue, I will continue in my original post rather than jump around. Had poor access to internet before, but now that I am back home will get this sorted easier.
Sn809 is offline
Faults fn2 code P2624 - VTEC Oil Pressure Switch Circuit Low Voltage kingskintim Engines and Transmission (8G) 19 6th January 2017 21:58
Oil K20z4 oil pressure switch pressure? rik220 Engines and Transmission (8G) 1 25th April 2014 11:14
FD2 cam+oil pump or FD2 intake manifold+throttle body+cpl cai iamsan Type-R 11 22nd May 2013 19:14
