Pcv valve replacement - Page 2 - Civinfo
 9Likes
post #21 of 43 (permalink) Old 18th May 2017, 12:49
CTR
Scottie1911's Avatar
Car: 2008 CTR, Milano Red
I ordered mine from Tegiwa last night, should be a simple fix.
Scottie1911 is offline
post #22 of 43 (permalink) Old 18th May 2017, 19:11
Spike85's Avatar
Anyone fitted an aftermarket hose. think its about 8mm I/D
no benefits only looks
Spike85 is offline
post #23 of 43 (permalink) Old 20th May 2017, 11:38
Spike85's Avatar
New valve arrived from USA today. Great 8 day turnaround for 11 posted. Parts made in Japan also. Will update results later
OOCH likes this.
Spike85 is offline
post #24 of 43 (permalink) Old 20th May 2017, 12:34
ASYella's Avatar
Is this an aftermarket or?
ASYella is offline
post #25 of 43 (permalink) Old 20th May 2017, 13:05
Spike85's Avatar
I'm not sure to be honest. Hasn't been labelled as genuine. But comes with warranty and is made in Japan.
Spike85 is offline
post #26 of 43 (permalink) Old 20th May 2017, 13:06
ASYella's Avatar
Maybe a start up company then
ASYella is offline
post #27 of 43 (permalink) Old 20th May 2017, 13:32
Spike85's Avatar
Spike85 is offline
post #28 of 43 (permalink) Old 22nd August 2017, 22:13
K20 addict
Danith's Avatar
Car: 2010 Fn2 & 2003 Ep3
Is there a how to, to replace?
Danith is offline
post #29 of 43 (permalink) Old 22nd August 2017, 22:26
Spike85's Avatar
I can write you one.
unclip Pipe
unscrew from block
refit new one
reconnect pipe
its that simple
Danith likes this.
Spike85 is offline
post #30 of 43 (permalink) Old 22nd August 2017, 22:27
K20 addict
Danith's Avatar
unclip Pipe
unscrew from block
refit new one
reconnect pipe
its that simple
Ha cheers. Winner. Is access an issue? Looks a bit tight. As you can tell I'm no mechanic, just a guy with a halfords socket set
Danith is offline
post #31 of 43 (permalink) Old 22nd August 2017, 22:36
Enjoying life
flashy's Avatar
Air con pipe is in the way a bit but still easy enough
flashy is offline
post #32 of 43 (permalink) Old 23rd October 2017, 11:21
Originally Posted by Harryhonda98 View Post
Thanks for this, was driving me crazy, thought it was the pulley or the VTEC solenoid valve, still cant seem to find a replacement for the 1.8, still never noticed a rough idle or excessive oil usage!
Sent from my SM-G920F using Tapatalk
Pcv valve are they easy to change? Or need to go to the garage to do it mines needing done
Kenneth05 is offline
post #33 of 43 (permalink) Old 23rd October 2017, 11:30
Enjoying life
flashy's Avatar
What model do you have? My Fn2 was a doddle to do.
flashy is offline
post #34 of 43 (permalink) Old 23rd October 2017, 14:02
K20 addict
Danith's Avatar
Even I managed it. 10 min doddle, just don't over tighten the new one on
Danith is offline
post #35 of 43 (permalink) Old 16th November 2017, 14:08
Car: 2008 NHB CTR
ok guys went to fit my new PCV valve today and the hose clip on the valve is upside down!
Any ideas how to get it off?
Megabreath is offline
post #36 of 43 (permalink) Old 16th November 2017, 14:24
Enjoying life
flashy's Avatar
Is it a grip one or screw/bolt type?
Can't you get a tool in there?
flashy is offline
post #37 of 43 (permalink) Old 16th November 2017, 16:07
Car: 2008 NHB CTR
Its a grip one, don't think i can get a tool in there. Its a bit tight
post #38 of 43 (permalink) Old 16th November 2017, 16:15
Enjoying life
flashy's Avatar
If you can get some long nose pliers in there to partially squeeze, you should be able to rotate the clip to get at it more easily
flashy is offline
post #39 of 43 (permalink) Old 17th May 2018, 01:11
sorry please delete
Campers is offline
post #40 of 43 (permalink) Old 17th May 2018, 01:14
where is this located on the 1.8 2006 civic ?
i looked on the picture on the other page , but that seems to be a different ,engine .
i dont remember mine looking like that .
i got some rattling noise starting from 1500 rpm and up .(most noticeble between 1500-2500 when doing engine brake) Dunno if its the pulleys , the cam chain or just something loose in the engine bay ( least likely ) .
I was quite sure its the pulleys , until i read about this .
Campers is offline
Other Pcv valve replacement fn2 Monty0881 Engines and Transmission (8G) 23 23rd August 2017 17:55
Other PCV Valve Andrew.Pike Engines and Transmission (8G) 4 9th March 2016 15:29
Other pcv valve advice please pebblefeline Engines and Transmission (8G) 4 18th May 2014 21:32
Other Has the 2.2 got a PCV valve??? OcTag3n Engines and Transmission (8G) 0 2nd July 2013 19:39
PCV Valve gasmanjay Cox Motor Parts 13 1st October 2012 20:52
