07 FN2 vibration when accelerating ?! - Civinfo
 1Likes
  • 1 Post By The cjrshop
post #1 of 18 (permalink) Old 20th August 2017, 08:50 Thread Starter
Hi Guys,
I have a new problem with my FN2.
When accelerating from around 90 to 130km/h 'ish in any gear the car seems to shake/vibrate from left to right.
Doing 100km/h either at constant speed or decelerating the vibration is gone.
The steering wheel doesn't vibrate. I feel it more in the chair, difficult to know if its the front or back of the car.
I got my new'ish tyres rebalanced and realigned (they were not bad). This seem to reduce the vibration by maybe 30%.
The car is basically stock and has done 170,000km.
Any advice or idea on what to look at or what could be causing this?
Cheers
Michael D'Silva is offline
post #2 of 18 (permalink) Old 20th August 2017, 10:00
Farqui's Avatar
Car: x'06 2.2 EX FK3 Milano
Eco display Eco display
Which tyres did you get replaced, front or both of all four?
Vibes thru the butt usually means an issue with the rear wheels/axle.
Farqui is offline
post #3 of 18 (permalink) Old 20th August 2017, 10:06
The cjrshop's Avatar
Car: 2006 1.8 ivtec Civic 8th Gen
Check your engine mounts had the same thing on a clio sport but was only visible when I jacked up the engine and the mount was split
Farqui likes this.
The cjrshop is offline
post #4 of 18 (permalink) Old 20th August 2017, 12:12 Thread Starter
all four, running bridgestone S001, still loads of tread
post #5 of 18 (permalink) Old 20th August 2017, 12:13 Thread Starter
If i grab the engine from top top and try and shake it, it doesnt move at all.
What do engine mounts look like? under my car is a kind of cover thing, do i rip it off?
post #6 of 18 (permalink) Old 20th August 2017, 20:21
Yes to test correctly you need to remove the undertray and place a soft piece of timber on your jack and jack the engine up very gently you can then see if the car stays put or lifts with the engine , I must stress do this carefully as to not damage the engine sump in anyway , while the jacks out jack up the car and check the driveshafts are nice and straight and cv boot condition.
post #7 of 18 (permalink) Old 10th September 2017, 10:39
Tee_tee110's Avatar
Car: 2007 1.8 ES 5Dr bluish Silve
I have the same issue, have been told possible driveshaft problem, anyone had them fitted? what do they cost?
Tee_tee110 is offline
post #8 of 18 (permalink) Old 13th September 2017, 20:22
Hi did you ever solve this problem, I have a Civic fn2 with the exact same symptoms?
Any help gratefully received.
Henry237 is offline
post #9 of 18 (permalink) Old 30th September 2017, 03:56 Thread Starter
Not yet, will get my machanic to look at my next service. Strangely it isn?t getting worse, but reduces my conference of my car to do what I tell it to do.
If it?s a ware and tear issue I?m surprised others haven?t seen it first as I don?t thrash the car (much)
post #10 of 18 (permalink) Old 13th October 2017, 07:57
Hello Michael.
My car is a 2006 Honda Civic 1,8.
I have the same problem as you (milage around 150000 km). The problem started when we had wintertires - "try change to summer,wheels that will doo!" - done that, same ****! Went to the Honda dealer (l live in Sweden) - "your tires has separated/are defect" - so we bought new one“s and had them really well balance at a quality wheelshop. - Same ****!
The car were at inspectiontest a couple of month ago - no complains...
I had both the inner cv-joint changed - same ****!
Now we changed the bearing, in the middle of the axel. (there is a holder for the bearing mounted on the engine). SAME ****!
Well, in the begining, the steeringwheel was shaking at the same time. But now only the car is shaking...
The problem is ONLY when I accelerates. If I drop the gaspedal - it stops shaking directly!
Please help me, my mechanic won“t even touch the beast anymore...
/Rikard
bmwricke is offline
post #11 of 18 (permalink) Old 23rd October 2017, 08:53 Thread Starter
I have the sameproblem as you
Originally Posted by bmwricke View Post
Hello Michael.
/Rikard
post #12 of 18 (permalink) Old 23rd October 2017, 14:04
K20 addict
Danith's Avatar
Car: 2010 Fn2 & 2003 Ep3
Getting one of mine replaced on Friday. £270 just for the part for passenger side
apparently water gets in behind the balancer mount on the driveshaft (half way along) and then rots the actual shaft itself which causes it to go out of balance and wobble, which in turn wrecks the CV. Ultimately the shaft will snap and he's seen a lot of Civics come in with snapped shafts now, due to the age they are now.
Danith is offline
post #13 of 18 (permalink) Old 27th October 2017, 16:27
K20 addict
Danith's Avatar
Done! So much smoother
Danith is offline
post #14 of 18 (permalink) Old 21st November 2017, 04:33 Thread Starter
Hi All,
I took my car in for an inspection. They told me my CVs are fine, as well as engine mounts etc. One thing they did say was that my Front suspension lower control arm rear bushes are very soft with excessive movement. They recommended i put aftermarket offset bushes to stop the "excessive movement".
Do you think this could be the problem causing the vibration?
Cheers
post #15 of 18 (permalink) Old 21st November 2017, 09:13
Farqui's Avatar
It's possible that worn bushes are contributing/causing the issue and replacing them isn't too costly. Why go for reinforced versions tho, new OEM spec should be fine.
Farqui is offline
post #16 of 18 (permalink) Old 9th January 2018, 05:32 Thread Starter
Does this look damaged at all? Want to make sure before buying new ones
https://ibb.co/n6rLbm
post #17 of 18 (permalink) Old 22nd April 2018, 13:10 Thread Starter
Hi All,
Updates on the situation:
Got my car serviced by trusted mechanic. He checked the mounts and bushes and could not see anything wrong/broken/degraded.
Thinking about it now, i did move many bags of concrete before i noticed the vibrations. Is it possible its my rear wheel bearings? How can i tell?
post #18 of 18 (permalink) Old 22nd April 2018, 13:21
Earth Dreams :)
Higgo8's Avatar
Car: 2017 CTR GT
Rear wheel bearings would tend to be a droning noise when you are driving.. not really a vibration..
Higgo8 is offline
08 FN2 vibration/shaking when accelerating Harryst500 Type-R 17 22nd April 2018 13:42
FN2 Tyre Troubles / Veering while accelerating Dj_CuRDLE Type-R 5 4th May 2016 20:55
fn2 judder/vibration at 2500rpm alanaikman91 Type-R 5 4th January 2015 21:29
Faults Fn2 vibration seantr Engines and Transmission (8G) 4 28th October 2014 22:40
FN2 clutch vibration MoOriginal Type-R 14 29th August 2008 16:53
