P2647 Error Code - Civinfo
 1Likes
  • 1 Post By Scottie1911
post #1 of 5 (permalink) Old 12th February 2018, 11:47 Thread Starter
CTR
Scottie1911's Avatar
Car: 2008 CTR, Milano Red
P2647 Error Code
Hello,
I'm getting the noted fault code (P2647 - A rocker Arm Actuator System Stuck on Bank 1), very low on power with very little revs
I took the vtec solenoid off (pain to get to) and didn't look like anything was wrong. After re-fitting it I cleared the fault and so far not appeared back
I haven't tried to go into vtec yet but can there be anything else causing the issue before I go get a new one?
Cheers
Scottie1911 is offline
post #2 of 5 (permalink) Old 12th February 2018, 12:36 Thread Starter
CTR
Update*** hit vtec and light back on with same error
post #3 of 5 (permalink) Old 16th February 2019, 13:17
did you fix this problem after?
Ahmed Ali is offline
post #4 of 5 (permalink) Old 18th February 2019, 08:31 Thread Starter
CTR
Yes it was the v-tec solenoid, once replaced no more fault code.
Farqui likes this.
post #5 of 5 (permalink) Old 26th February 2019, 11:20
Car: 2010 CTR-22758 GT, Red
Worth knowing.
s3 akr is offline
Faults P1384 Error Code HeadStand Engines and Transmission (8G) 10 20th November 2017 10:39
Electrics Error code help Spookyleaf Bugs, faults and irritations (8G) 5 6th February 2017 17:52
Faults Error code oggyogg85 Engines and Transmission (8G) 0 10th July 2014 15:37
Faults Error code 1.2 I_broke_my_civic Engines and Transmission (8G) 2 4th November 2012 02:46
Tech p2004, fault code, error code. help! 786evo8 Engines and Transmission (8G) 5 9th August 2012 19:19
