2 little problems - Civinfo
 4Likes
  • 3 Post By musegroove
  • 1 Post By Wilmo
post #1 of 8 (permalink) Old 12th July 2018, 19:16 Thread Starter
2 little problems
Hi since owning my 08 type r I can't seem to get the cruise control to work or the aircon iv cahanged the the fuse relay and it has plenty of gas I can hear it running but it isn't cold does the 2 coolant fans cool the aircon as they are not running
Seanvx is offline
post #2 of 8 (permalink) Old 12th July 2018, 20:26
regrets his username
dweezle's Avatar
Car: 1.6 focus RS
Check to see if the cruise control plug is connected, located on or just above the clutch pedal, it often gets left unplugged if it's had the master cylinder replaced.
AC could be a leak, condenser, your best bet would be to use an AC specialist rather than Honda, Honda you could be looking at 4-600 quid
dweezle is offline
post #3 of 8 (permalink) Old 12th July 2018, 20:44 Thread Starter
Ok thanks mate I will check that plug tomorrow
Seanvx is offline
post #4 of 8 (permalink) Old 13th July 2018, 07:40
250bhp.... finally :)
musegroove's Avatar
Car: 08 CTR, Milano Red
Likely the CC switch needs to come out, give it a spray with electrical cleaner and reinsert. The pedal doesn't depress the switch all the way or it gets stuck. Only takes a few mins and just need a 17 spanner.
Alternatively unlocking the nut and turning the switch half a turn further down can sometimes resolve the issue.
Kremmen, Bones126 and Das like this.
musegroove is offline
post #5 of 8 (permalink) Old 13th July 2018, 10:07
Das
i-Vtec
Das's Avatar
Car: 2009 1.8 ES
Not sure if its both fans that run with the AC on, but yes the radiator fan should run with the AC on.
Das is offline
post #6 of 8 (permalink) Old 13th July 2018, 18:10
Wilmo's Avatar
Both fans should be running when the AC is on especially if you have run it for a while.
Das likes this.
Wilmo is offline
post #7 of 8 (permalink) Old 13th July 2018, 19:55 Thread Starter
I think that's my problem then none of the fans come on , so maybe a fuse ?
Seanvx is offline
post #8 of 8 (permalink) Old 13th July 2018, 21:24
Das
i-Vtec
Das's Avatar
Car: 2009 1.8 ES
Cheapest place to start id say.
Das is offline
A little Goodbye for my little legend of an FN2! Cazza And goodbye 40 28th January 2013 22:15
Interior Little Blue light Parky Lights (8G) 47 4th February 2009 13:11
Black My Little Fella!! jme1978 Gallery (8G) 12 6th September 2006 17:21
I Gotta Little Problem. :( AubreyS Site suggestions, feedback and rules 2 28th August 2006 11:44
Little help please. spidy2442 General Discussion (8G) 1 6th July 2006 11:18
