Rear noise driving me mad - Civinfo
post #1 of 37 (permalink) Old 3rd March 2013, 18:11 Thread Starter
Iamgj02's Avatar
Car: 2008 CTR, Milano,
58 Milano CTR
When going over an uneven surface, not so much potholes or speed bumps, at low speeds 1-20 mph I get a knocking type noise coming from the rear or the car, sounds like drivers side, like the rear seat belt is knocking on the plastic interior.
I've taken out everything in the boot and bays, parcel shelf if not the issue.
What are the possible causes
Defiantly at the rear
Iamgj02 is offline
post #2 of 37 (permalink) Old 3rd March 2013, 18:16
regrets his username
dweezle's Avatar
Car: 1.6 focus RS
Passenger seat belt is usually the cause in my car
dweezle is offline
post #3 of 37 (permalink) Old 3rd March 2013, 18:17 Thread Starter
Iamgj02's Avatar
I make sure that is hooped over seat where I can see it
Iamgj02 is offline
post #4 of 37 (permalink) Old 3rd March 2013, 18:27
Robstokie's Avatar
Car: 2009 1.8 ES Sapphire
I've got the same issue, still trying to narrow it down
Robstokie is offline
post #5 of 37 (permalink) Old 3rd March 2013, 18:29 Thread Starter
Iamgj02's Avatar
What have you done so far ?
Sent from my iPhone 5 using Tapatalk
Iamgj02 is offline
post #6 of 37 (permalink) Old 3rd March 2013, 18:50
dweezle's Avatar
Car: 1.6 focus RS
Boot lid rubber stops may need turning up so the boot lid is resting on them
dweezle is offline
post #7 of 37 (permalink) Old 3rd March 2013, 18:51 Thread Starter
Iamgj02's Avatar
Done that, they're maxed
Iamgj02 is offline
post #8 of 37 (permalink) Old 3rd March 2013, 19:06
Porks's Avatar
Had same problem today it was something around the rear head lining was like a buzzing plastic sound. Searched high and low even got mrs to drive car around with me sitting in the back. I removed rear roo grab handle refitted it better by tensioning the clips a little more. I then pressed all over the headlining and something clipped into place in the center part that hides blind mechanism and now all is well. Good luck with finding yours I know how frustrating it can be
Porks is offline
post #9 of 37 (permalink) Old 3rd March 2013, 19:10
Boost Time...
jonno66's Avatar
Car: 2008 CTR NHB
Send a message via AIM to jonno66
I get an annoying squeek coming from the rear over uneven surfaces at slow speeds, tightened the Mugen wing a bit more as I have noticed it more since I put it on last year. .. but still the squeek is there gets on my t*** .....
jonno66 is offline
post #10 of 37 (permalink) Old 3rd March 2013, 19:14
dweezle's Avatar
Car: 1.6 focus RS
Is it the vtec hamster I've heard about
dweezle is offline
Thanks to dweezle from:
post #11 of 37 (permalink) Old 3rd March 2013, 19:16
Bulky's Avatar
Car: 2011 CTR GT Alabaster silver
Could be the rear dampers , have someone sit in the back with half the back seat down , I narrowed my 'knock' down to suspension , rear dampers replaced and its gone !!
Bulky is offline
post #12 of 37 (permalink) Old 3rd March 2013, 19:18
dweezle's Avatar
Car: 1.6 focus RS
My rear knocks 1st thing but dissappears after a few mins quite common I heard
dweezle is offline
post #13 of 37 (permalink) Old 3rd March 2013, 20:41 Thread Starter
Iamgj02's Avatar
Not much to see but you can defiantly hear it
It's so bad on certain roads now
Iamgj02 is offline
post #14 of 37 (permalink) Old 3rd March 2013, 21:56
Keep On Vtec'ing!
snoopy's Avatar
Car: 2009 Renault Megane Coupé
Same here as well, i initial thought that something major had gone wrong with my car lol
snoopy is offline
post #15 of 37 (permalink) Old 3rd March 2013, 22:02
"Grandad eye"
stevey_p7's Avatar
Car: 2007 1.8L CTS Silver
Is the trolley jack secured in place properly? To me it sounds like something thats behind a covered area. I know you said you'd got everything out the boot. Just making sure you'd not left the trolley jack and tools in that hidden compartment.
Sounds like something in a shoebox moving about, that'd be the way I describe it anyway. Well until you've found it, just get that music on full blast
stevey_p7 is offline
post #16 of 37 (permalink) Old 4th March 2013, 00:16
Dave84's Avatar
Car: 2009 CTR GT, Albaster Silver
Thats the best cure tbh. I have the same in mine too. Have you up rated anything on the rear, dampers or bushes. My boot lid makes lots of rattles, nothing you can do in IMO maybe to do with the car being so stiff.
Dave84 is offline
post #17 of 37 (permalink) Old 4th March 2013, 04:37 Thread Starter
Iamgj02's Avatar
Tbh it's not something I'm prepared to live with, I know the car makes noises and rattles and I have lived with that, but this is something that's happened over the last few days, a new noise and it is very very annoying,
I'm going to double check the boot bays but I am almost positive they are completely empty.
Jeeeez this thing has been on my mind that it's woke me up this early thinking about it ???
Iamgj02 is offline
post #18 of 37 (permalink) Old 4th March 2013, 09:40
Cockup Specialist
Relic's Avatar
Sure its not the hidden wheel well door ?
This will bounce up and down with the bumps if there is no weight holding it down.
Relic is offline
post #19 of 37 (permalink) Old 4th March 2013, 10:20
Tuppers's Avatar
Car: 2010 2.2 SI
Can you move the tailgate locking mechanism by hand ? If so the latch has worked loose.
Several existing threads discussing this, but basically I had to remove the internal tailgate skin and tighten the two allen studs.
Tuppers is offline
post #20 of 37 (permalink) Old 4th March 2013, 11:17 Thread Starter
Iamgj02's Avatar
I'm pretty sure it's tight and no movement is there,
I've also had someone on the back seat with the seat down pushing down on the wheel hatch door and the noise is still there
Iamgj02 is offline
Knocking noise when driving?? ying General Discussion (8G) 1 20th August 2012 01:21
Suspension Noise from rear end. stemil Wheels, Tyres, Suspension and Brakes (8G) 1 10th March 2012 13:07
Other Tapping noise whilst driving? spike4real Bugs, faults and irritations (8G) 3 14th August 2010 01:03
Suspension Noise from rear suspension dobbie Bugs, faults and irritations (8G) 28 16th August 2008 15:50
Windows Driving with rear window open. pcr Bugs, faults and irritations (8G) 14 28th September 2006 00:18
