Spark Plug Change 148, cheap? - Civinfo
post #1 of 80 (permalink) Old 5th March 2013, 11:57 Thread Starter
jameseh's Avatar
Car: Orchid White GG6 Si
Been quoted 148 inc vat to supplied and fitted by local dealer. Is this reasonable? They won't tell me what make plugs but said are iridium type and 18 each.
Any thoughts?
jameseh is offline
post #2 of 80 (permalink) Old 5th March 2013, 12:00
ash_rage's Avatar
Car: 2016 CTR FK2 GT - Milano
Literally takes me 30 minutes to do them all. Plugs can be expensive, 72 sounds tad over priced.
So they are charging 76 labour, not bad for dealer price to be honest.
ash_rage is offline
post #3 of 80 (permalink) Old 5th March 2013, 12:05
stoney's Avatar
Car: 2007 FN2 GT
Do them yourself pal. As ash says its a quick job.
stoney is offline
post #4 of 80 (permalink) Old 5th March 2013, 12:43
Eddcheng's Avatar
Car: CTR Milano Red fn2
DIY it, plugs from Tegiwa are very good priced and the recommend ones by Honda NGk so it's 36 for plugs and 30 mins of labour
Very easy to do I did mine last night with oil and oil filter and it took 1.5 hours for the lot.
Eddcheng is offline
Thanks to Eddcheng from:
post #5 of 80 (permalink) Old 5th March 2013, 13:55 Thread Starter
jameseh's Avatar
I knew the plugs would be expensive but the labour isn't actually too bad really.
I was thinking about DIY but I remember seeing the How-To and it involved taking the windscreen wipers and cowl off, not as easy as I expected!
While I was there I asked for the valve clearance check and adjustment they quoted 72 inc VAT. Very reasonable from a dealer! So it's booked in tomorrow and dropping the car off today. The woman I spoke to over the phone knew about checking it stone cold so she's pretty clued up.
Looks like I'm starting to trust dealers now lol
jameseh is offline
post #6 of 80 (permalink) Old 5th March 2013, 14:01
stoney's Avatar
Car: 2007 FN2 GT
The cowl pops off and the cover is only 6 small bolts . the wipers stay on.
stoney is offline
post #7 of 80 (permalink) Old 5th March 2013, 14:05
discus's Avatar
Car: 2010 CTR, Milano red
Thieving ba***rds, plugs are 9 each assuming you are not having anything posher than Bosch Platinum. The specialist's who service the Porsche only charge 70 for a plug change (including plugs) - and that has 6.
Do it yourself.
discus is offline
post #8 of 80 (permalink) Old 5th March 2013, 14:08
stoney's Avatar
Car: 2007 FN2 GT
K series use iridium
stoney is offline
post #9 of 80 (permalink) Old 5th March 2013, 14:14
discus's Avatar
Those were the plugs Euro car parts came up with for my reg, NGK's are about the same prices so my point still stands.
discus is offline
post #10 of 80 (permalink) Old 5th March 2013, 14:15
delta0's Avatar
Car: RX-8 R3, Blue
R series also uses iridium too. A lot of faff having to take the windscreen cowling off by the sounds of it. Normally it is just an engine cover off job. As these plugs last so long it was probably not the top priority to have easy access. Although in a service it is normal to back them off and tighten again. Also they do check the plugs at the service, so they do have them out sometimes.
delta0 is offline
post #11 of 80 (permalink) Old 5th March 2013, 14:16
Martin.ring's Avatar
Its the price in Denmark for the spark plugs alone witout laber..
But they can drive 120000km before they need to be change again..
Martin.ring is offline
post #12 of 80 (permalink) Old 5th March 2013, 14:18
stoney's Avatar
Car: 2007 FN2 GT
Porsche probably charge 2k for an air filter though Lil
Euro car parts are wrong
stoney is offline
post #13 of 80 (permalink) Old 5th March 2013, 14:19
aka Paul
Revs FN2's Avatar
NGK Iridium plugs are available online for 30 odd quid for 4. Easily swapped if you have a socket set with a spark plug socket. Everything else is clips and 10mm headed bolts.
Revs FN2 is offline
post #14 of 80 (permalink) Old 5th March 2013, 14:35
discus's Avatar
My last service with the Porsche was cheaper than the Civic, 234 including all filters and 8 litres of Mobil 1.
discus is offline
Thanks to discus from:
post #15 of 80 (permalink) Old 5th March 2013, 15:21
stoney's Avatar
Car: 2007 FN2 GT
Your awesome
I like bran flakes
stoney is offline
post #16 of 80 (permalink) Old 5th March 2013, 15:33
aka Paul
Revs FN2's Avatar
You're awesome
I like bran flakes
If you're gonna be a smart arse you could at least spell it right
I like Just Right
Revs FN2 is offline
post #17 of 80 (permalink) Old 5th March 2013, 15:38
#darkside
Andrew Moore's Avatar
Car: 2015 LCI M135i
Did mine without taking anything off other than spark cover. Takes 20mins. 4 bolts on spark cover, disconnect battery, remove 4 studs for coil packs, 17mm spark plug socket (I think) and away you go. In and out easy as pie.
Andrew Moore is offline
post #18 of 80 (permalink) Old 5th March 2013, 16:34
stoney's Avatar
Car: 2007 FN2 GT
I thought Smart phones were mean't to be smart
stoney is offline
post #19 of 80 (permalink) Old 5th March 2013, 16:55
#darkside
Car: 2015 LCI M135i
Apple are the worst for poor spelling mistakes or totally incorrect words.. love it lol
post #20 of 80 (permalink) Old 5th March 2013, 16:59
stoney's Avatar
Car: 2007 FN2 GT
How dare you mention Apple
Android
stoney is offline
spark plug wrench rajanm1 Engines and Transmission (8G) 9 29th September 2012 21:21
New spark plug's? MiChA Type-R 5 18th August 2010 11:45
Other Spark plug Gap settings JSYSH466Y Engines and Transmission (8G) 0 15th August 2010 13:47
spark plug cover of a ep3 daz4311 Type-R 2 21st July 2009 16:59
