Suspension Whiteline Rear ARB problem - Civinfo
post #1 of 13 (permalink) Old 10th July 2019, 14:52 Thread Starter
Car: 2007 1.8 Type-S
Question Whiteline Rear ARB problem
Advice needed from anyone who has one and fitted it themselves.
I bought and fitted a Whiteline rear ARB to my FN2 CTS. It was fitted by a skilled mechanic who has spend 40+ years building and racing rally/hillclimb cars.
After about a month, I noticed the back end had returned to the handling state before it was fitted. Took a look and the washer on the bolt that secures the ARB to the spings lower mount was stretched and had popped through the hole:
The hole the washer covers is quite large, not much smaller than the washer itself.
Is this the same for anyone else who has fitted one of these or are my components different? I cant find any other instances of this issue on this forum or the wider world of google.
I have replaced the washer with a new thicker one and added an extra bolt between the bracket and the spring mount to improve, but curious if I am alone in this.
bagpuss0001 is offline
post #2 of 13 (permalink) Old 10th July 2019, 16:45
Cheddars's Avatar
Car: 2009 1.8
Sad to hear they have problems, mine should be here before the weekend so will reply when I get around to fitting.
I had one on a Bertone Astra I had years ago. Bar the rubbish paint work as it chipped so easily, it was a good bit of kit.
Cheddars is online now
post #3 of 13 (permalink) Old 11th July 2019, 15:42 Thread Starter
I agree, a fantastic mod and makes so much difference. I compete in hill climbs with my CTS and it gives so much more confidence with the ARB fitted.
The thing is, I am not sure if its a design problem with the kit or my car has been modified in the past.
Feedback from all other drivers having these on civics is top notch. Cant see a product getting that good a rep with such a flaw.
post #4 of 13 (permalink) Old 11th July 2019, 23:08
seejay's Avatar
dont they come with multiple washers so you fit them i a reverse pyramid to lock in?
seejay is offline
post #5 of 13 (permalink) Old 12th July 2019, 12:58 Thread Starter
Not my kit, no.
All washers were used with no leftovers and the instructions only mentioned one washer.
post #6 of 13 (permalink) Old 12th July 2019, 20:05
seejay's Avatar
There are
File Type: jpg B0E7E666-91B2-4716-8EB8-DAFC2B0A214B_1562958270476.jpg (58.4 KB, 13 views)
File Type: jpg BA97F3D1-8847-4DC8-A586-77EE72615189_1562958290086.jpg (108.5 KB, 10 views)
File Type: jpg 2EF4E339-E3AF-4106-B9DD-584ECD996DF9_1562958307170.jpg (74.4 KB, 9 views)
seejay is offline
post #7 of 13 (permalink) Old 14th July 2019, 11:06
Cheddars's Avatar
Car: 2009 1.8
Fitted mine other day, not impressed at all with the design
There is alot to criticise, but in fairness the car handles great
post #8 of 13 (permalink) Old 15th July 2019, 16:01 Thread Starter
Thats different to my kit - dont think the extra washers were there and the chap who fitted it definitely had none left over.
I'ce checked my revised fitting - after several 'rigourous' journeys with lots of fast bends and they are still ok, so hopefully its secure now.
post #9 of 13 (permalink) Old 15th July 2019, 16:03 Thread Starter
My heart says "weld it" the head says "take off and sell if I change cars"
post #10 of 13 (permalink) Old 15th July 2019, 16:06 Thread Starter
Ah - I can post pics now.
Here is the washer, popped through
https://www.dropbox.com/s/c0eoizii8m...85028.jpg?dl=0
Here is the size of the hole in the spring cup - the clean metal is the ARB bracket beneath
https://www.dropbox.com/s/kmihcuez8x...10308.jpg?dl=0
Here is my revised fitting with extra bolt
https://www.dropbox.com/s/812zo9udhm...20312.jpg?dl=0
post #11 of 13 (permalink) Old 15th July 2019, 16:26
Cheddars's Avatar
Car: 2009 1.8
That looks worrying
Think I might copy that idea
post #12 of 13 (permalink) Old 16th July 2019, 12:32 Thread Starter
It does line up with an existing hole in the spring seat - I didnt need to drill, but I did need to use a spring compressor on one the offside spring to give the clearance to pop the bolt in. The coil of the spring got in the way.
Loose fit all bolts so there is play to wriggle the bracket to line up all the holes and it will be fine.
I'm still going to keep an eye on it every weekend.
post #13 of 13 (permalink) Old 16th July 2019, 12:39 Thread Starter
Also, after chatting with the friend who fitted it, if it stretches and pops through again, we will remove the spring seat and weld in a support to plug the hole the main bolt uses, drill 11m hole in it and bolt the bracket to that. Then we retain the ability to remove the ARB if/when I sell the car and replace it with a CTR .
  Civinfo > 8th Generation Euro Honda Civic (2006 - 2011) > Wheels, Tyres, Suspension and Brakes (8G)
Tags
whiteline arb
