9G lowered but still comfortable possible? - Civinfo
 2Likes
post #1 of 39 (permalink) Old 1st August 2015, 15:48 Thread Starter
Deserter to Lexus
dougie175's Avatar
Car: Lexus IS250
I know Honda did a lot of work to make the 9G far more comfortable than the 8G was, which in my opinion was required!
However they made it about 25-30mm too damn high for my liking. Obviously they is easily fixed with a set of Eibach or similar springs.
My question is obviously the ride will become firmer with Eibachs and a set of 18s on but does it destroy it completely? Does it send the car back to the level of comfort I would associate with a lowered 8G?
I know the Germans can achieve a lowered car with relative comfort, is it possible with the 9G to get the same?
dougie175 is offline
post #2 of 39 (permalink) Old 1st August 2015, 15:50
anthropolyte's Avatar
Car: 2008 Type R FN2, NHB
I would suggest fitting proper, high quality coilovers. You can then adjust the damping to your preference.
anthropolyte is offline
post #3 of 39 (permalink) Old 1st August 2015, 15:54 Thread Starter
Deserter to Lexus
dougie175's Avatar
Car: Lexus IS250
Have a set of coilovers been developed for the 9G though that actually give you a more comfortable ride of the most comfortable setting than stock dampers and eibach springs?
I don't believe this has been achieved on the 8G so I would be surprised if it has on the 9G?
post #4 of 39 (permalink) Old 1st August 2015, 16:03
Meister R for the 8G.
Not sure if they have a set that fits the 9G.
post #5 of 39 (permalink) Old 1st August 2015, 16:09 Thread Starter
Deserter to Lexus
dougie175's Avatar
Car: Lexus IS250
Cheers
No they don't do a set for the 9G as far as I am aware
Who has claimed that Meister R's are more comfortable than Koni's matched with Eibachs that I run for example?
Never heard of someone saying Meister's make the 8G more comfortable, less crashy yes but comfortable no?
I know Allan switched from Konis and Eibachs to Mesiter's but don't think anyone has achieved comfort through Meister's?
post #6 of 39 (permalink) Old 1st August 2015, 16:19 Thread Starter
Deserter to Lexus
dougie175's Avatar
Car: Lexus IS250
I have messaged Meister R directly, if they honestly believe they have a setup that can give a comfortable coilover I would be willing to splash out on a new setup for my 8G, only reason I would switch to the 8G would be for a bit of added comfort and refinement.
post #7 of 39 (permalink) Old 1st August 2015, 17:06
Farqui's Avatar
Car: x'06 2.2 EX FK3 Milano
Eco display Eco display
I totally agree with you, my Meister's have banished the crashy ride. But they ain't comfy with 5kg springs per corner and I have Polybushes fitted
I'm mighty tempted to give 4kg springs a try, especially on the lighter rear.
If I do and they're an improvement, then I'll let you know.
Will be interested to hear what Meister come back to you with. I haven't pinged them yet.
Farqui is offline
post #8 of 39 (permalink) Old 1st August 2015, 17:07
Farqui's Avatar
Shame we aren't closer, otherwise you could have a demo.
Farqui is offline
post #9 of 39 (permalink) Old 1st August 2015, 18:02 Thread Starter
Deserter to Lexus
dougie175's Avatar
Car: Lexus IS250
Jerrick basically said hes not sure as everyones opinions on comfort are different. He did say to try someones though, but the problem is distance from well.... just about EVERYONE on here!
Currently with 18's on I can literally feel every imperfection in the tarmac, I am not saying its uncomfortable or I cant live with it, but it certainly doesn't give a feeling of quality or comfort. I don't always want to have to be in "race mode" I realise I could quite easily improve the ride by fitting 16's but aesthetics are also very important to me, other manufacturers seem to have managed putting large alloys on but still having comfort and acceptable handling!
As I said to Jerrick I am quite happy to loose some of the performance handling in favour of comfort if it is possible, there must be a way surely!
post #10 of 39 (permalink) Old 1st August 2015, 18:07
Farqui's Avatar
The dampers provide a good range of adjustment and with 5kg's I find I'm at the fully soft end. The springs ride over every bump. With 4 adults onboard the ride improves.
I figure if I change to 4kg's that I'll be able to set the dampers further away from soft. Hopefully on softer springs bumps would then be absorbed.
On the motorway or smoother roads, my current setup is okay. I just need to improve the ride over rougher roads. The lanes around here are pretty bumpy
Farqui is offline
post #11 of 39 (permalink) Old 1st August 2015, 18:18
Helmigurt's Avatar
Car: 2016 CTR GT, Polished Metal
I Eibach'd my 9G and have 18" wheels on it and while it is definitely harder then stock it's still quite usable on a daily basis. It's not too hard for normal road use.
EarthDreams likes this.
Helmigurt is offline
post #12 of 39 (permalink) Old 1st August 2015, 18:19 Thread Starter
Deserter to Lexus
dougie175's Avatar
Car: Lexus IS250
Do you find your setup more comfortable than stock, I know comfort is subjective, but I am sure you notice when you in your other half's Golf how much more "comfortable" the ride feels than the civic?
I have recently take a lift to work with my friends old A3 running on very cheap and nasty JOM coilovers and even that felt far far more comfortable than my civic, my springs alone cost more than his entire coilover setup! Not to mention my Koni FSD dampers!
post #13 of 39 (permalink) Old 1st August 2015, 18:20 Thread Starter
Deserter to Lexus
dougie175's Avatar
Car: Lexus IS250
Thanks for the input, have you ever rive a 8G? How would you say it compares not it has been lowered and on 18s?
Also how would you say it compares to other cars out there of similar size?
post #14 of 39 (permalink) Old 2nd August 2015, 16:41 Thread Starter
Deserter to Lexus
dougie175's Avatar
Car: Lexus IS250
Just went out for a test drive in a 9G, was a nice drive, however don't think I could personally justify the cost increase over my own car.
Sales man was very much pushing me to buy a brand new pearl white 1.8 sport. Was a very nice bit of kit, but with the costs involved I would never end up actually owning the car!
Thanks to dougie175 from:
post #15 of 39 (permalink) Old 8th January 2016, 09:01
You should try the Bildtein B12 pro Kit. It comes 3cm down and its still comfortable but progresive.
bauchti is offline
post #16 of 39 (permalink) Old 8th January 2016, 17:14
Nickolodeon's Avatar
Car: 1.6 iDTEC ES
I have just put my old Astra G 2.2 on Bilstein B6 shocks and Eibach pro kit springs back on the road and it is more comfortable in terms of ride comfort than my bog standard Civic 1.6 iDTEC on the crappy Sachs dampers. I don't know why but they just don't seem to be tuned with the springs very well, the standard 9g civic rides shockingly bad in my opinion, suspension is noisy and crashy over bumps and bouncy and never settles properly. Car was like this from brand new.
Nickolodeon is offline
post #17 of 39 (permalink) Old 14th March 2016, 22:31
I sold my 8G type s because of the brutal ride. Decided I couldn't live with it anymore. Had the standard 17inch alloys on it.
I now have an astra 2.0 vx line with 19 's, sport suspension and the ride is miles better. I can't understand why Honda couldn't sort the suspension out. I've driven the 9G 1.6 and whilst it is better than the 8G, it's still a bit primitive on the suspension front.
Sent from my SM-G920F using Tapatalk
Reddamper is offline
post #18 of 39 (permalink) Old 15th March 2016, 21:55
Car: 1.6 iDTEC ES
Interesting that you also found the 9g not all that great a leap forward in terms of ride compared to 8g. Never driven the 8g, and the Astra g on paper is very similar set up, struts up front and torsion beam rear, bog standard cheapo car setup, but the Astra either on standard or uprated suspension is a bit more comfy I find.
Thanks to Nickolodeon from:
post #19 of 39 (permalink) Old 16th March 2016, 13:57
Eisenhut's Avatar
Car: 2014 Civic T 1.8 Lifestyle
I fitted H&R springs on my 9G tourer and even if the ride is firmer, I think it's more comfortable since the springs are progressive.
It now rides perfect in my opinion.
Eisenhut is offline
post #20 of 39 (permalink) Old 16th March 2016, 14:16
Helmigurt's Avatar
I did ride a 8G for a day (while my 9G was in service) and it was horrible to be honest. I guess the Eibach'd 9G is firmer but less crashy if that makes sense.
Thanks to Helmigurt from:
  Civinfo > 9th Generation Euro Honda Civic (2012 - 2016) > Wheels, Tyres, Suspension, Brakes (9G)
Suspension Baby coming, Comfortable ride for my FN2 borg Wheels, Tyres, Suspension and Brakes (8G) 8 8th July 2014 12:50
Comfortable diesel saloon JohnnyBoy Any non Civic chat here please! 58 29th April 2013 22:58
R-Red got lowered ryan d Gallery (8G) 17 28th January 2012 22:01
Black My FK3 Lowered Alpha Gallery (8G) 6 5th May 2011 09:58
It looks like I've had my car lowered, Right? stevey_p7 General Discussion (8G) 15 8th July 2010 16:24
