2006 civic OSR door lock won't open - Civinfo
post #1 of 1 (permalink) Old 11th August 2013, 14:41 Thread Starter
Can anyone tell me how to remove the osr door lock from a 2006 civic 5 door car, the electric actuator has failed in the locked position so the door will not unlock with the key remote, or with either the handle inside or outside.
I want to remove the lock to fit a replacement , but cannot do so until the screws are removed on the door lock face which cannot be reached until the door is open.
Do I need to drill into the lock from inside the car to manually turn the actuator, I have removed the inside door panel already.
Any info welcome.
pkgreen is offline
  Civinfo > Knowledgebase (Wiki) > Wiki Article Discussion
Bodywork Door sensor thinks door open becasue of dent in door xorsch Bugs, faults and irritations (8G) 11 11th May 2011 18:08
