[Fixed] Squeeky Parcel Shelf - Civinfo
post #1 of 15 (permalink) Old 27th November 2011, 11:18 Thread Starter
Fonzey's Avatar
Car: 2005 Subaru Impreza WRX STi
I know that Parcel Shelves are noted as a common cause of squeeks/rattles on the wiki, but I couldn't find any documented 'fix' for it.
Last night when driving home from a meal, I noticed a series of squeeks each time the road was a little rough/bumpy coming from the tailgate. My missus was driving (I'd had a few too many, which kind of explains my next stunt).
I turned the stereo off, undid my seatbelt and clambered into the back of the car. When putting pressure down on the parcel shelf, you could replicate the squeeking and if you put enough pressure onto the parcel shelf, you could 'compress' it completely and the noise stopped.
I fixed this today by using two packs of 3x adhesive strips from wilko's. (about 1 each). Three strips was just enough to cover the plastic trim 'ledge' which the parcel shelf sits on at either side, so got that lot stuck on - and when stood in the Wilko's carpark I could no longer replicate the squeeks by pushing down on the shelf.
Drove home with no radio on, and the sound is cured.
I can grab some photographs if needed, but wasn't sure if this was worth adding to the Wiki somewhere.
Fonzey is offline
Thank You to Fonzey from 3 Users:
post #2 of 15 (permalink) Old 14th December 2011, 19:04
hagan71ctr's Avatar
Car: CTR GT CHAMPIONSHIP WHITE
put some photos up bud i have that same annoying problem
hagan71ctr is offline
post #3 of 15 (permalink) Old 16th December 2011, 13:19 Thread Starter
Fonzey's Avatar
I shall do so tonight!
Fonzey is offline
Thanks to Fonzey from:
post #4 of 15 (permalink) Old 17th December 2011, 12:34 Thread Starter
Fonzey's Avatar
Pretty simple... get in your back seat and push down gently on the centre of your shelf. If that replicates the sound you get whilst driving, then sticking some foam strips as below will solve it.
Got mine from Wilko's, but I'm sure you can find similar all over the place
Fonzey is offline
Thank You to Fonzey from 2 Users:
post #5 of 15 (permalink) Old 18th December 2011, 12:48
hagan71ctr's Avatar
cheers bud did mine today & hey presto that bloody annoying creaking sound has gone
post #6 of 15 (permalink) Old 18th December 2011, 15:46 Thread Starter
Fonzey's Avatar
Excellent, well worth the trip to wilkos!
Fonzey is offline
post #7 of 15 (permalink) Old 26th December 2011, 02:47
opjepass's Avatar
Great idea, thx Fonzey!
I`m going to check it out at my car tomorrow!!
But I think the color of the foam strips don`t look so smart,
why didn`t you use something like this ebay article 230720907173 ?
I think this would be some kind of an "upgrade" and looks a bit more gently...
Sincerely, opjepass
opjepass is offline
post #8 of 15 (permalink) Old 26th December 2011, 08:43
Living the dream!
I have a neater way of doing this just apply some packers in side the 2 rubber tubes on the back hatch that press on the shelf when the hatch is closed, if these press harder then the shelf will not move etc
RickHondaR is offline
post #9 of 15 (permalink) Old 26th December 2011, 11:35 Thread Starter
Fonzey's Avatar
Sincerely, opjepass
Good Shout, may be a new year upgrade for me
Fonzey is offline
post #10 of 15 (permalink) Old 14th May 2013, 07:28
Marty says BWAAAHHH!!!
optiknerv's Avatar
Car: 09 Milano Red CTR GT
The squeak itself is caused by the rubber pins rotating within their slots. Obviously by limiting up and down movement of the shelf with the sticky foam strip you can eliminate this.
I had a slightly prettier fix and what I did was get some black electrical tape and wrap a few layers around the rubber pins to make them fatter. Now any movement means that the shelf rotates around the rubber pins rather than rotating the entire pin in the slot and squeaking.
optiknerv is offline
post #11 of 15 (permalink) Old 28th July 2013, 18:48
Many thanks.. This has been annoying me for ages!
Wattsy08 is offline
post #12 of 15 (permalink) Old 5th August 2013, 20:49 Thread Starter
Fonzey's Avatar
Glad to hear it's still helping people
Fonzey is offline
post #13 of 15 (permalink) Old 9th March 2014, 16:29
fav150's Avatar
I've just done this fix. I've been looking for something to use as I wanted it to black so it wouldn't stand out. Whilst waiting for my mrs in hobby craft I found a sheet a black foam with sticky sided the other side
0.80 with loads left to maybe to do it double thickness.
Quite pleased with the results
fav150 is offline
Thanks to fav150 from:
post #14 of 15 (permalink) Old 21st April 2015, 16:55
NathanJones's Avatar
Car: Type S 1.8 I-Vtec Bronze
I've also done this! Massive help!!
NathanJones is offline
post #15 of 15 (permalink) Old 21st April 2015, 16:59
Airzi69's Avatar
Car: 2008 FN2 nighthawk black
i dont think mine squeeks? sometimes a problem reading forums you find problems you never knew you had. i shall be listening
Airzi69 is offline
  Civinfo > Knowledgebase (Wiki) > Wiki Article Discussion
