1 - 20 of 52 Posts
I am thinking of purchasing a civic but am unsure which model to get.
I drive about 8000 miles a day and daily commute is about 6 mins on dual carriage each way to work and 4 mins in stop go traffic. I currently have an old cicc 1.6 vtec and its great but the 1.6dtec is appealing due to mpg and free road tax. The issue I have is that as i dont do many miles per year and I may get problems with the DFP which I believe is expensive to repair?
Any advice please?:confused:
8000 miles a day - should justify a diesel with that!!
Seriously - I doubt you would justify the additional cost of a diesel doing £8K per year - numbers are fairly easy to do.
If you look at the genuine expected mpg (not that quoted in the sales guff).
Genuine figs are all arguable but if the diesel does say 60mpg @ £140p/lr then it is going to cost you 10.5p/ml for fuels
A petrol car at 45 mpg @ £135p/lt will cost 13.5p/ml
at 8000 per year you will save £240/year in fuel - but the car will cost you more to buy and service (but will also retain part of that additional cost at trade in time). - you can do your own sums to suit
As for the PDF issue - I have no experience of this in Honda's yet but diesel usually need a decent run now and again - your motorway mileage MIGHT be sufficient if it is free flowing
8000 miles a year i meant :)
You knew what i meant....lol.
Does it cost more to service the diesel than the petrol?
I hear so many scary stories about DFP problems and may just stick to the 1.8 vtec. as am just doing the 8000 a year.
Cockup Specialist
Its not the yearly milage which is the main issue.
The mian problem is the short journeys.
I dotn know about the 1.6 but the 2.2 takes 20mins or more to reach operating temp.
Only at operating temp will the engine run properly and clean itself out provided you aren't gentle.
The kind of short journeys you are talking about could be very very bad for a diesel with dpf as you suspect.
That's said I have never really heard of DPF issues with the 2.2 idtec or euro iCDTi.
There have been oil level rising issues which need an eye on...but there isn't a whole host of DPF replacement threads.
So in that aspect the Honda appears really good from that point of view.
Note the 1.6 is also and complete redesign...much lighter..much less friction..may use less oil and warm up much quicker.
Personally....I would never buy another diesel due to them using a dpf.
The UK iCDTi 8th gen don't have dpf.
Discussion Starter #9 (Edited)
With the 20 min journey a day I do then i suspect that may be a problem with the DPF.
What is the main difference with the 1.8 petrol and 1.6 dtec, driving wise?
When I was at the dealers I overheard this gentleman talking about the DPF problems he have had with his CRV but it was a older model so maybe not useful info.
seems a pretty contradictory post!! first you say the short journeys will be bad for a diesel with DPF, then you say you have never heard of a 2.2 diesel with DFPF issues!
Not meaning to slag you off but mixed messages don't help any one
Cockup Specialist
The 1.6 has 250 lb ft torque so will accelerate like the 2.2 at low rpm but run out of puff at high rpm.
But.....the 1.6 is much much lighter...100kg so should have better power to weight, handling and braking than the older heavier diesels.
The 1.8 should be similar weight to the 1.6 but requires staying in gear and using the full rpm range to get the best from it.
So the 1.6 is more of a eco cruiser with good easy power on tap..but will run out of puff pushing on.
The 1.8 is still very economical car....but you have to work it more and approach redline to get best performance.
Depends on the owner really I guess.
Cockup Specialist
Short journeys is bad for DPF universally.
Its just the Honda specifically doesn't appear to suffer to the same degree as a lot of other manufacturers.
Nothing contradictory there.
Just the way it is.
I like to sit behind merc, bmw, audi, vw diesels when the temps are 30c+.
Most appear to smoke. The Honda not. So it appears to run much cleaner.
Discussion Starter #14
Good Explanation Relic.
Whats the mpg for the 1.8 vtec roughly. Is it around 42 on a mixed run?
Cockup Specialist
Coudlnt say mate.
Ive seen some return 60mpg on the dash on a good run.
Seems to be on a par with the 2.2 diesel MPG in most areas except eco motorway cruising.
2.2 Diesel sees around 38 in winter around town.
Summer its closer to 42+ heavy town use.
The 1.8 guys will fill in any blanks where they are concerned.
If you're only doing 8k miles a year, a diesel engine doesn't really pay for itself for quite a while. You should go with a petrol.
I got my diesel because my commute alone is 72 miles per day, that adds up to 1,656 miles per average month on commute alone, not including social and leisure. So since I get close to 20k miles per year, the diesel was the sensible option for me.
aka Paul
The 1.8 Civic should feel similar, power wise. Bit more power but a bit more weight.
I use this website to record my motoring costs and the search facility can be use to find real world mpg figures - since users are recording actual fuel used and mileages it is as accurate as you will get - Advanced search - Spritmonitor.de
Honest John also allows you to search "real" mpg's but there is no control over whether users are real figures or those from the On Board Computer. OBC's tend to be optimistic but I believe the Civics is not too far out. Real MPGs | Honest John
Honest John puts the 1.6 Dtec at 63.3 mpg and the poof powered 1.8 at 41.4 mpg
1 - 20 of 52 Posts
