1 - 20 of 95 Posts
Muscles From Brussels
I know there will be mixed views but all views would be amazing! I'm wondering if anyone one has put a cold air feed on the cts before and whether it made any difference performance wise I know it would be small but every little helps ;) and did it make a throatier sound?
Discussion Starter · #4 ·
Cheers o both of you! Love that filter but as ive just picked up a k and n panel I'm thinking about experimenting with some hosing leading down to where the horn is? I know what you mean about ctrs my cars used for work so I need a little bit of economy plus I can insure a boxster for the same price as a Ctr!!!!
You're on to something interesting there. You should get a noticable difference in performance although you wont get that lovely sound.
Things to consider....
The best place for a feed is the Wheel arch as its a high pressure zone. you should get a big difference by getting rid of all that garbage resonator and maze of plastic pipes.
Going to the grille I found the engine to be a tad sensitive and would sometimes cut out under harsh decelleration. I'd go with the grille as the first option. just make sure you secure everything properly. Foglight garnish maybe?
Reactions: RobertUtley
Discussion Starter · #6 ·
I was thinking remove the foglight mesh and have it there only thing I'm worried about is water and crap being dragged up into it! I'd love to do a little behind the grill modification and run it along the front only problem is is I have a Perspex grill :,( I know I know you feel for me aswell hahaha tbh all I want is a subtle roar when I leave silly 1.2 corsas at the lights but not too much as I've had all the loud roar before and now want a sleeper
Discussion Starter · #10 ·
Sadly enough I read that earlier :/ I was initially researching derestricting the air box as ie owned four vauxs and each I derestricted and the throttle response was better but after reading a thread about it and the stick the guy got for removing the air directional fins etc and the hundreds of negative comments I decided that wasn't a good idea plus relic backs this up I may try and get my hands on some cheap pipework in the future and have a play with a cold air feed! Keep an ear out for anyone with some old garden hose ;) hahah
£20 for a large diameter flexi pipe anyou can have loads of fun :worms:
I've got several K&N cold air feeds if you want them? the've been in my secret boot compartment for quite some time.
Discussion Starter · #12 ·
How far will they reach and how much you want for them!?!? Cheers in advance and coste1l I've seen hundreds of threads and all have you in them with comments that make me cry with laughter just thought I'd show appreciation to the humour!
I'LL NEVER WALK ALONE
why not just fit a K&N 57i ?
too much time on my hands buddy :D
Cockup Specialist
I'm interested in this... So do you plan to put the tubing on the inlet of the oem air box and then simply run it down to the grill?
I know very little about this stuff lol, so can someone explain why the wheel arch is a high pressure zone? Surely a pipe with minimal bends from the fog light/grill area will allow faster/higher pressure air into the airbox?
1 - 20 of 95 Posts
