1 - 2 of 2 Posts
Moderator
On the 10G, there is a handy 12V Aux point on fusebox B in the driver's footwell.
It's fuse 5 which is named as Accessory Cut in the book. The top of the fuse is the live side.
Use an Addafuse with the original 10A fuse in the lower fuse holder and a fuse of your choice in the upper one.
There is also a handy earthing point close by. The 10mm bolt that holds fusebox A to the chassis. (6mm lug required). It's the one upper left with the two blue lugs in my photo.
Fuses 1-5 are permanent live and fuses 5 to 7 are Aux switched.
1 - 2 of 2 Posts
