It's all about doing things in the right order with me.....so now I've had my stage 1 re-map & paddle clutch - its time to think about slowing down a little quicker
On the basis that my journey to work takes approx 5 mins & I only give it a slight thrashing at weekends, what do you guys recommend? I started looking at the Mtec discs, but then thought if they are only rated to 650 degrees - what advantage do they have over standard discs (other than the grooves milled into the surface). For pads I was going to go for mintex on the rear & yellowstuff on the front......but then I saw costel had mentioned bluestuff because yellowstuff would eat oem discs - but reading the review on bluestuff they are track focused so wouldn't these have the same effect too? Trying to keep spending to a minimum & I was also going to buy some braided steel lines, so whats best?
