Had a engine engine warning light appear, i checked the ECU for diag code and it shows P2004 - which i think relates to
18436/P2004/008196 - Intake Manifold Flap; Bank 1: Stuck Open
Possible Causes
  • Vacuum leak
  • Faulty Intake Manifold Runner Position Sensor1 (G336)
  • Intake Manifold Runner binding or sticking
Has anyone had this code before on 2.2???
Very common issue on the Accord ictdi guys. It's the solenoid valve which also acts as an actuator for the EGR valve..
We can now map these out as part of remap with EGR OFF ;)
If you want to replace the part itself, it's about £140 from Honda.
Check this thread on Typeaccord for more info:
Slight Missing or Hesitation, Excessive Smoking etc - TypeAccord
Interesting. So what's the price for remap
Is it the Celtic map?
Before and after roller readings ?
Seen your name mentioned a couple of times when reading threads about mapping diesels. But what company do you work from ?
Have you done many members cars?
Sorry for the blunt questions lol
Absolutely not.
We're part of Elite Remaps, and all the info you need is in the forum inc dyno plots, both on our dyno and other dyno's. We've been well known in the Accord community for a good few years, and only joined this forum earlier this year hence the reason you may not have heard of us.
Countless Accords, Civics and CRV's tuned now and plenty of member cars.
