1 - 9 of 9 Posts
So my garage took off my undertrays to sort out a fuel pipe leak and turns out they have lost all the bolts to put it back on.
Usually I wouldn't car but the car failed it's MOT today because the loose trim is fouling the tyre so it needs to go back on.
Anyone know what bolts I need? I can get the clips obviously.
Clutch pedal guru
Simple solution, they lost them, they get and fit replacement ones.....
You should be able to secure the wheel arch liner without the undertray, I ran mine without whilst proving a FMIC install. Numerous forum members have removed their without issue too.
Is it the same garage that failed to reinstall the undertray that has failed it's MOT because of this?!
Just zip tie the current piece of trim that's touching the wheel to the nearest securing location.
Mine doesn't have a undertray to the engine.
Clutch pedal guru
Same
1 - 9 of 9 Posts
