1 - 10 of 10 Posts
I've discovered the passenger side rear electric window isn't working on my 2.2cdti with either the switch on the drivers armrest or the passenger rear switch
Any ideas what it could be or where to start
Civinfo Wind Up Merchant
Start with the window reset:
Electric window reset procedure - Civinfo Wiki
If that still doesn't work i'd hazard a guess the motors kicked it, If all other windows work and neither control will move the window.
You can also remove the door trim and then the switch module (both drivers and the non-working one) and check the switches are both powered; with a multimeter probe. (the switch module box comes apart to the pcb.)
Is there any way to switch the switches around just to power the window that won't go down just to allow me to fit wind deflectors ?
Depends if the motors knackered or it's a switch issue.
You could remove both rear door switches and see if the the connectors fit, i've not compared the two connectors to be honest; so im not so sure.
Sorry no; i mean remove both rear door trims and remove the switch housings and see if the connector from the other side fits the wiring on your "broken" side.
I couldn't tell you if the connectors fit or not but it may be worth a shot.
Cheers mate that makes sense but as it works from neither front drivers switch or rear passenger switch I'm assuming your right with the motor being goosed
I would have thought so from what you've said mate.
If it's the TeamHeko deflectors you can get those in without the window being down if you're careful im sure, wont be ideal and a bit tight, but should go.
1 - 10 of 10 Posts
