Hi since owning my 08 type r I can't seem to get the cruise control to work or the aircon iv cahanged the the fuse relay and it has plenty of gas I can hear it running but it isn't cold does the 2 coolant fans cool the aircon as they are not running
regrets his username
Check to see if the cruise control plug is connected, located on or just above the clutch pedal, it often gets left unplugged if it's had the master cylinder replaced.
AC could be a leak, condenser, your best bet would be to use an AC specialist rather than Honda, Honda you could be looking at 4-600 quid
250bhp.... finally :)
Likely the CC switch needs to come out, give it a spray with electrical cleaner and reinsert. The pedal doesn't depress the switch all the way or it gets stuck. Only takes a few mins and just need a 17 spanner.
Alternatively unlocking the nut and turning the switch half a turn further down can sometimes resolve the issue.
i-Vtec
Not sure if its both fans that run with the AC on, but yes the radiator fan should run with the AC on.
Both fans should be running when the AC is on especially if you have run it for a while.
