Hi guys
As above my tailgate wont lock. The remote doesn't open or close the tailgate neither does the button on the tailgate! I thought i would check the fuse first but the tailgail fuse isn't mentioned in the manual!! Can anyone help me please?
Tim
I expect the tailgate will be fused with the rest of the central locking. Is the central locking working ok? Does the pull lever beside the seat still work (or does the tourer not have an internal release lever?
I've found out what was wrong with my tailgate and its fixed. The tailgate has a fail safe so when the tailgate is closed with sonthing in it it fails open. To reset this i just had to take the battery off for a couple of minutes and its fixed and saved myself a fortune!!
Tim
You Saved me £389.24p
Went into Hoda and they said I needed a new lock!
Thought I would check 1st.
WOW cant believe Honda would want to rip its customers off so badly.
Stay clear of Yomans Littlehampton.
You should definitely press the 'Thanks' button for t111bul on that one then!
