Hi All
I recently purchased a 2007 EX. I've sorted out most of the niggles, but I still have one annoying one - The AC system is making a nasty noise.
I replaced the pollen filter, which was black and full of leaves. I'm guessing that the fan is also full of junk and that's what is causing the noise.
However, I can't find the fan. I'd prefer not to start pulling off random bits of dash, so was hoping someone here knew where to look.
I assume that if the fan is full of leaves it's worth giving the system a clean. Any advice on the best method for this?
Shaun
Behind the center console
If you get down and look behind the cewter console you can see it
Dont know how easy it is to get to
If you open all your vents and put fan on full do you get bits cuming out leaves ?
Nothing comes out at full blast.
I shall have a go at removing the centre console. I watched a youtube video about it, and it seems fairly straightforward.
Thanks.
