Bye bye Honda...
Watched the vidclip but not sure what you're trying to draw attention to... is the car revving itself at idle or was it you? Or is it something else?
I realise there maybe a language barrier, but it would be better if you could describe the problem and give a few details of the problem, when it began, what triggers it, what makes it stop, have you looked for stored fault codes, is the problem only when idling, etc?
All I can guess at the moment is that the accelerator pedal position sensor may be playing up.
By the looks of it your check engine light is on and your car is in limp mode. Do you have an OBDII scanner/reader?
If you can read the code this will help greatly.
Clutch pedal guru
pls check out this video
youtube.com/watch?v=-dGMsNZk0gU
what is the problem?
Stick in a proper description of the issue and a proper link and we might be able to help you?
