1 - 20 of 37 Posts
Below are the latest prices for fast road and suspension packages for the Civics.
Stage 1. Full alignment setup front and rear including front adjusters and rear shims (Based on 2 shims used - Extra shims are £7.05 each)
£231.12 incl VAT
Stage 2. Supply and fitting of 15mm Eibach prograssive springs and the Type-R and 20mm on other flavours, full alignment setup front and rear including front adjusters and rear shims (Based on 2 shims used - Extra shims are £7.05 each)
£530.08 incl VAT
Coilover packages are available upon request.;)
I vtec'ed your mum!
Hi, I have just brought KW V1 Coilovers, how much to fit, and apply the fast road setup up to the car while your applying the coilovers?
Thanks,
i-VTEC - DO YOU?
Hi, i was just wondering is this the same price for TDI South aswell??
Cheers :D
No. They use different equipment and have different labour rates.
Thanks,
Hello
Your looking at about £350
Difference between us and TDi South as has been said is just the hourly rates. ;)
i-VTEC - DO YOU?
would someone be able to tell me how much TDI South will charge then please?? :)
Best bet is to give them a ring direct, send them a PM or post a thread in the TDI section and wait for them to get back to you.
I vtec'ed your mum!
Hello
What's your hourly rate then? Thx
i-VTEC - DO YOU?
how much for 15mm eibachs and front FRS only all fitted?
:hijacked:
Really, the rears are usually most out of alignment and will make a difference to your handling. Depending how much cheaper it is I'd recommend you consider getting the rears done as well.
I vtec'ed your mum!
No they cost a bit more as they have a higher hourly rate I believe. And I think that's around the 70 mark but you best check that!
I know.... thats what I meant. TDI North are cheap compared to TDI South...
Its all about location =)
And I agree with J_H I would highly reccomend getting both front and rear done. Well worth the money!
Go Hard or Go Home!
ive just reached 25k on the clock so im thinking.. service + eibachs + frs. could you quote me all in inc. vat and labour ect please :) thanks
That is certainly part of the answer, but the largest consideration is the cost of the capital equipment.
Just the dyno and suspension calibration spaces alone cost a quarter of a million Pounds at TDI South, which is part of the reason we are able to deliver exceptionally high quality outputs :)
Mugenised CR-Z GT
Personally there labour rate is cheap, the Honda dealer I am at is £90ph
Reactions: TDI
Big T
if any of you are in doubt about the FRS, get it done it has transformed my cars handling with springs aswell.:D
Reactions: BronzeCivicTypeR
1 - 20 of 37 Posts
