1 - 20 of 52 Posts
Hi just wondering how much the alloy fuel flap is and how does it fit and if it can be removed with out damage as the car is a lease car don't want to get one and damage flap so get changed in 3 years thanks
Looked on honda site and says 135£ that's a bit steap wonder if any traders doing them cheaper still want to how they fix . Thanks I'll look
You can find it on coxmotorparts.
81£ that's for black
Chrome is nearly 100 £ that a good bit more than black
Thanks I don't think I will bother as you have to drill flap.
Living the dream!
you could always leave it fitted when you return the car then you would have no hassle as to be fair this is a genuine Honda accessory
Dead easy to fit. You just need to release a tab internally and it slides off. Can email you fitting instructions.
So do you don't need to drill them then ? Yer can you send to me in pm thanks
No problem will send them this evening.
No drilling whatsover, you basically remove the existing lid by releasing an internal tab with a flatbladed screwdriver (cover the tip in masking tape to prevent damage) and then slide and click the sports cap in place.
Discussion Starter #12
Sounds easy thanks
I think you didn't fit it correct. Did you slide it? Did you hear click?
Στάλθηκε από το GT-I8190 μου χρησιμοποιώντας Tapatalk
Do you have instructions of fitting?
If not, i can send them to you but on Monday morning
1 - 20 of 52 Posts
