Is this all i need to fit a 2din stereo?
Speakers are upgraded to front hertz and rears whit infinity , soo thats done...
For te radio i was looking at Pioneer FH-X700BT, its only 160e.
And the fascia from C2 Civic Full Kit LDH
That's all you need to fit a double din. The 700bt may be cheap but sure you will regret not paying more and getting a touch screen unit, you can do so much more with the Pioneer Appradio units for example.
Thanks :) . Yes your right about the radio, its abot 350e for the tuch screan pionner radio, not that much more. :)
I have been looking at the same conversion for the 2 din. Do this come with the metal cage to mount radio or is it going to be siting loose in the new fascia.
The connects2 fascia comes with brackets the head unit attaches to - no cage is required. You can also use a cage but not the standard 113mm one that comes with a headunit, you need a 103mm high one.
