1 - 2 of 2 Posts
Yorkshire Jedi
Evening chaps
Hoping you can give me a quote for the following.
1. 5 year service ( 18k ish on clock atm )
Using FUCHS TITAN RACE PRO S 5W40 oil with HAMP filter
Also it may not be on the schedule but would like gearbox oil and spark plugs changed (using the best products in your expert opinion).
I am happy to supply the Oil and filter if it would be cheaper but I'm hoping you can be competitive ;)
2. FRS, I have OEM springs
3. Bulb upgrade to HID's
I'm looking to bring the car in 10th or 24th November and it would be a big help if the work can be completed same day, if not service needs to be done first.
(Looking to get brakes & springs upgraded in Feb)
Cheers :)
Hi Ben,
Further to our chat on the phone earlier;
We spoke about doing the 6th service, just so you know where you're starting off from, as a relatively new owner.
And then for front and rear FRS, using shims in the rear to get the correct setup.
So prices for the both, using a maximum of 4 shims in the rear (so it could work out cheaper) and NGK plugs in the service, rather than the more expensive HKS;
6th service - £371.50
F & R FRS - £224.00
Hopefully speak to you later Ben, and see you on the 10th @ 9am :)
All the best,
Rich
1 - 2 of 2 Posts
