Hello mates !
While messing around with the a/c diagnostics I have managed to change the values on the temperature range. Lowest setting is now 15 and highest is now 29, the "low" setting is 18 degrees.
On auto the fan speed is flat out and never seems to go cold now so I think I have messed something up.
Any clues?
Oops, does the A/C diag menu have a 'Reset to Factory Default' option?
Not that I can see, can't make any sense....will try unplugging the battery but doubt that will reset to factory settings.
Maybe the different temperature range is for a different market, middle east where they have a yellow ball in the sky that generates heat more often than not!
