1 - 13 of 13 Posts
With the weather warming up this month, it soon became obvious the A/C was'nt actually chilling air into the cabin.
Had the 'standard' re-gas but still the system wouldn't deliver ice cold air. Tried swapping the A/C relay and bingo, the system's fully functioning.
Well worth the approx. £18 off ebay for a relay. Probably cold weather's back on the way but roll on summer.
Mine does blow cold but not consistent, actually seems worse when it's hottest!. Will invest in a new relay.
That's how mine was. Good luck with a new relay !
linky to the ebay purchase?:popcorn2:
mine stopped kicking in today but had it regassed recently!
Hi cb glad you solved AC problem, where is the AC relay?
It's in the fuse box in the engine compartment next to the bulkhead. The relay concerned is black/4 pins and marked Omron G8HL-H71
I've just replaced the relay and my aircon still isn't working. When I switch the aircon on, the engine noise does change pitch but I can't hear the relay click. Any suggestions?
The only thing I can suggest is take it to a specialist who has diagnostic equipment to check the system.
1 - 13 of 13 Posts
