Hi Lads and lasses,
I've been running the JRSC kit for some time now and I've only now had "P2A00" fault code show up on Hondata. After I had the initial check engine symbol come on I ran a diagnostic that revealed the air flow meter/oxygen meter has gone belly up. Does anyone have any suggestions? I remember someone tried to warn all the S/C guys that this could be an issue, but I cant find the thread!!
Will it be safe to drive? Would Honda still cover me under warranty although the car is supercharged? Worry, worry, worry. Please help!
Thanks in advance :D
You do not have to worry about this. I have a 3rd AFR sensor already. First was cover under warranty but next 2 not. Except the "check engine" light and you wouldn't be able to tune your car correctly and there would be many incorrect readings on your Flashpro, anyway it's recommended to have a fully working AFR sensor .
Hope this helps
Thanks Dawid, how's the Frankenstein project going? Are you fully up and running? :D
Yep, fully satisfied :)
Does anyone know where I can buy one of these oxygen Air/fuel sensor from the UK other then Honda? Part number 36531-RSP-E02, Australia charges 600+!! :(
