1 - 20 of 27 Posts
Honda Civic Type R FN2 Servicing prices
Remember all of our services are carried out to the exact correct Honda specification with your service book stamped and Manufacturer’s warranty unaffected.
FN2 Type R (’06-‘10)
1st service, 12,500 miles or 12 months
Labour charge £60.00
Oil filter & sump washer £11.50
Oil (5lt) £38.00
Consumables £8.40
Total £117.90
2nd Service, 25,000 miles or 24 months
Labour charge £120.00
Oil filter & Sump washer £11.50
Oil (5lt) £38.00
Air filter £19.50
Consumables £8.40
Total £197.40
* Valve clearances checked at extra cost
* Cabin filter change required (if fitted)
3rd Service, 37,500 miles or 36 months
Labour charge £66.00
Oil (5lt) £38.00
Brake fluid £13.00
Consumables £8.40
Total £136.90
4th service 50,000 miles or 48 months
Labour charge £126.00
Oil (5lt) £38.00
Air filter £19.50
Consumables £8.40
Total £203.40
5th service, 62,500 miles or 60 months
Labour charge 60.00
Oil (5lt) £38.00
Consumables £8.40
Total £117.90
6th service, 75,000 miles or 72 months
Labour charge £195.00
Oil (5lt) £38.00
Brake fluid £13.00
MTF gear oil £25.00
Air filter £19.50
NGK Spark plugs £50.00
Consumable £8.40
Total £360.40
7th Service, 87,500 miles or 84 months
Oil (5lt) £38.00
Consumables £8.40
Total £123.90
8th Service, 100,000 miles or 96 months
Labour charge £72.00
Oil (5lt) £38.00
Air filter £19.50
Consumables £8.40
Total £149.40
9th Service, 112,500 miles or 108 months
Labour charge £90.00
Oil (5lt) £38.00
Brake fluid £13.00
Consumables £8.40
Total £160.90
10th service, 125,000 miles or 120 months
Labour charge £130.00
Oil (5lt) £38.00
Air filter £19.50
Coolant £9.00
Consumables £8.40
Total £216.40
Pollen filters (if required) @ £14.00
Valve clearance check @ £60.00
*Car has to be stone cold to carry this out correctly so preferably left overnight*
Any other questions, don't hesitate to get in touch. By PM on here or phone me on 01270 567177 ;)
Rich
Got my Civic booked in next week with you guys for its 5th yr service and MOT plus fitting new discs and pads
Type EX,A guy called Mark
Can you pm me a cost for the below but with no spark plugs, brake fluid or air filter (have K&N 57i) needing to be done as I have just done these. Just so I get an idea for when my service is due. Thanks
Labour charge £179.00
Oil (5lt) £38.00
Brake fluid £13.00
Fuel filter £44.00
MTF gear oil £25.00
Air filter £24.50
Spark plugs (HKS) £82.00
(NGK) £59.60
Consumable £8.40
Total (HKS) £425.40
(NGK) £403.00
Oil (5lt) £38.00
Brake fluid £13.00
Fuel filter £44.00
MTF gear oil £25.00
Air filter £24.50
(NGK) £59.60
Consumable £8.40
Total (HKS) £425.40
(NGK) £403.00
PM Sent
Cheers, Chris
Hi Chris,
"Valve clearances checked"
what does this entail ?
Checking the valve clearences is pretty much as it says. We remove the rocker cover and measure the cleanrences, using a feeler gauge on both inlet and exhaust valves.
We would then adjust any which were outside the required measurements.
Rich
Price please on a
without Brake fluid £13.00
without Air filter £24.50
with NGK plugs
with Valve clearances checked
with Cabin filter change required
ManU
Price please on a
with NGK plugs
ManU
Oil (5lt) £38.00
Fuel filter £44.00
MTF gear oil £25.00
Spark plugs (NGK) £59.60
Consumable £8.40
Valve Clearence check & adjust £55 inc vat
Total £420.50
Don't have a price on the cabin/pollen filter sorry but will on Monday if you contact me then.
Cheers, Chris
Hi Chris,
When should the coolant be changed and what it's the cost ?
Using ABP motorsport for over 25 years now
ManU
Hi Chris,
ManU
Honda have the coolant change down to be carried out at 125k miles, or 10 years.
It is a longife, red coolant and so doesn't need to be replaced regularly.
Long life coolant we keep @ £4.50 per litre. A total for flushing the system, and replacing the coolant with new would be £71.50 inc VAT.
Hope this helps,
Rich
Rich will you send me the total cost for the 5th service and value clearances at £55 plus an mot and then will arrange to book in for the start of march hopefully
Discussion Starter #12
5th service is only minor, at £112.90 which includes changing engine oil and filter and a complete check over and report. Valve clearance check and adjust is, like you said, £55.00 and an MOT just £45.00.
A total cost would be £212.90 inc VAT. Obviously we'd need the car ideally the night before, to let everything cool down before doing the valve clearances the following day.
Do you want to give me a call to book in, or let me know what day is best for you?
Rich
Discussion Starter #14
post deleted..!
Sorry you were in a rush for the quote.
From what you mentioned, you'd be best doing a major service which covers everything, gear oil and plugs included as well as engine oil, air filter and brake fluid. We do it to Honda spec, including full vehicle check at £360.40 inc VAT.
I think you mentioned valve clearances, which need to be done on a cold engine. That's £60.00 for check and adjust.
Again, apologies for not being able to reply as quick as needed.
Rich
Hi rich. How much for a 10 year service inc valve clearance, brake and transmission oil change? I believe the coolant will also need to know be done. Car has done 26000 miles
Sent from my SM-N910F using Tapatalk
Discussion Starter #16
10 year service is 216.40 inc VAT, comprising of engine oil and filter change, air filter and coolant change.
Gear oil would be £55.00 inc VAT, using the Honda MTF fluid. Brakefluid would be £43.00 inc VAT.
We would check the coolant strength and brakefluid moisture content before changing them as they may well be perfectly adequate with the low mielage on the car.
Let me know what you think.
Rich
Rich
Sounds good rich. Mine is not due till sept so will get it booked for August. Will be bringing my own oil if it makes a difference? Also is it worth getting a new air filter that doesn't require changing every year?
Discussion Starter #18
If you're using your own oil, it'll save you about £40.00 off the service price.
We keep in stock the k&n panel which only requires cleaning every couple of years, that's £45.00 inc VAT. Slightly better flow and million mile warranty.
We also keep the HKS RSK which is a full intake kit, which gives good gains on cam and sounds great. That's £349.00 inc VAT.
Let me know when you're ready and we'll get it sorted.
Rich
Rich
Sounds marvellous rich. Will be in touch. If getting valve clearances done the car needs to be cold and I'll be travelling from reading. Is there anyway round this
Discussion Starter #20
It is best to leave it with us the night before, but if that's not possible, it would be with us for the day. First thing to do the service etc and then valve clearances towards end of the day when the engine is properly cold.
There isn't any other way of doing it unfortunately.
Rich
1 - 20 of 27 Posts
