1 - 2 of 2 Posts
Hi
I recently got the Foxwell NT650. To try and identify where the problem was coming from but there doesn't appear to be any error code related to the dash warnings.
When I initially ran the test there was an 86-16 /Perm anent DTC fault under the sas test but there was no dash light relating to the airbags and it hasn't reappear after clearing the fault.
I took it to the garage at the start of the year and they replaced the RL wheel speed sensor. The light did go off but it then came on again a month later.
The ABS / VAS warning appears as soon as you turn on the ignition. It's been on for a while now and I have no idea what could be causing it. Any one got any ideas? Is there a way to just clear the fault?
https://photos.app.goo.gl/SkdtrHiz4dCNzTqd9
1 - 2 of 2 Posts
