1 - 2 of 2 Posts
Hi I changed both the front speed sensors today with new discs and pads as I had a front right speed sensor code , but now I have the abs and vsa lights on constant and I checked the code and it says 146-06/permanent dtc CAN system failure and still has the front right speed sensor code as well does anyone know what the can system failure is car is a 08 fn2 type r
I had something similar, but replaced the sensor and it went away.
You should check the rear sensors too as mine had been encapsulated by corrosion and broke
1 - 2 of 2 Posts
