Hey to anyone that may be able to help, recently bought my Honda civic from and have had no real issues other than the AC not working. Originally was told it had no gas in its system so paid to have it regassed in the hopes this would resolve the issue, needless to say it did not and was told that most likely the external temp sensor had gone and buying a new one and replacing should fix things. So I have bought and fitted the new sensor myself and still the car shows no outside temperature on the dash and the AC shows no sign of working in the near future, ideas would be much appreciated ? ?
Oh dear, when the AC was regassed did they initially perform a vacuum test for leaks?
I don't suppose they added UV dye? - to help you find any leaks.
The condenser is a common failure so check for dark patches on the matrix and around the hose fittings.
What relay are you running? - early versions are known to be dodgy.
When it initially went in to get regassed it was found to not be holding pressure, however they told me they then ran nitrous through the system and it seemed to hold pressure ? and after gassing it again it was still holding.
Will check for any dark patches around the compressor and matrix, had not thought of that.
Have not checked relay yet either am fairly new to anything DIY with cars, forgive me for any ignorance ?
Ok, so after removing the old relay and causing a massive headache by dropping it into the tray underneath and the having to remove the entire front bumper to retrieve said relay I may have mad some progress.
Wasn't sure how to determine whether the relay was dodgy or not without putting power through it, so found a fairly similar four pin relay from a Nissan which only just fits the box.
With the new(old) relay in all of a sudden the fans seem to blowing much colder air through the cabin, however there is still no outside temp reading showing on the dash ?
same time do you guys experience, that the sideline air-holes are always blowing, independent from the setting?
(seems to be controlled together with the windscreen, and not with the wholes mid console)
I've also noticed that. Dunno if that is normal or not.
