Hello
Basically, how do I access the harness from the interior? I would like to know, so then I can feed cables/wires throgh for speakers etc..
Please help:)
Best Regards Dan :?
Dan, hi. Which bit of the wiring harness do you need to access, and what are you trying to do?
Discussion Starter · #3 ·
Hey
Basically, I want to connect the wire to the battery back, and then feed it through into the car, but I dont have a clue on how to get into the car from the engine, but I have noticed there is a hole where a load of wire go into.. maybe that's the access?? If so, how do I get to it:S
Regards Dan
Discussion Starter · #5 ·
Thank's man, how ever still abit confused, how do you actually access to that point from the inside of the car?:S maybe more pictures? if its not hassel
:roll:
Then best way is to feed the cable into the car from the Engine side and you will see it coming through into the car if u lie on the drivers side floor and look up behind the dash.......2 man job without a doubt.
