Anyone know
What are the advantages in having a phone that is on the honda approved list.
Other than you cant download the phone book ?
I guess it just means that they are certain it will work with their phone kit. I'm having a bluetooth put into my new civic next month and before they would confirm the order, they went to check if my phones were compatible with the kit, or else they wouldn't have sold it to me.
I have a nokia n82 and that works ok other than you cant download the phone book.
I also have a nokia 6300i that also works ok and you can download the phone book
It states on the www.hondahandsfree.com site the n82 is Not compatible but works as I have used it to make and take phone calls.
I cant say the 6300i works any better either
I have a Blackberry Curve and a Nokia N96 paired to my HFT. The Blackberry is fully compatible and works a treat, the N96 is not officially compatible but is capable of phonebook transfer etc.
That said, the Nokia has a habit of connecting to the system when it wants to be conected to it, and has a habit of rebooting itself and then not being visable to the HFT.
I conclude from this that some phones that are "not compatible" with the HFT simply because they are unstable, and Honda quite rightly does not want to put it's good name against some of the shoddy and rushed to the market phones that Nokia and perhaps others are putting out there.
Also worth noting that "compatible" does not always mean full functionality. A compatible phone may not have the ability to transfer its phonebook. However, as long as you can find a phone that will transfer its contacts, then any paired phone can access it.
Thanks for that
I have tested Iphone with it and that works fine including the phone book.
I gave up with my Sony W715 due to it losing phonebook every time I switched off the ignition, ended up manually voice tagging and dictating numbers into it.
Which was quite easy as I don't have too many contacts
