1 - 2 of 2 Posts
Another member suggested I post in here for FRS settings for my Civic.
I have a 2008 1.8 Sport, 5 dr. Car is running standard suspension and springs on 17" alloys. I do not have any plans to lower so just looking for settings as is.
He mentioned I would probably require shims for the rear and you would be able to advise what size I need and quote me a price.
Geometry results attached
In fairness your rear geometry doesn't look too bad at all. Ideal camber on the rear is 1 degree negative but as the shims only come in either 1/2 or 1 degree neither will get you exact. As your settings are quite similar side to side I would be tempted to leave the rear as it is.
You do however need a set of front camber bolts to get the front camber closer to 1 degree negative at each side and once thats done get the front toe reset.
Camber bolts in stock here at ABP @ £25 pair inc vat.
Call us to order on 01270 567177 or we can book in for fitting and alignment set-up ;)
Cheers, Chris
1 - 2 of 2 Posts
