Sitting in the dentists waiting room yesterday morning I made the mistake of flicking through one of the (German) car magazines.
I found an advert for this HUD on amazon.de:
There are apparently 2 versions, both of which connect to the OBD2 connector.
One gives tyre pressure via external sensors, which replace the valve caps and the other also gives tyre temperature from internal sensors.
Anyone got one of these already?
Any opinions?
Thanks.
Civinfo Wind Up Merchant
"Whats the point" is my opinion :p
If it had useful information then it'd be awesome.
But i check my tires regurlary enough to know there inflated hehe
Your car is loverly mate!
aka Colin
i think that looks quite cool, but im sure i could spend the money on something better.
Afternoon folks,
I tripped over this via Google whilst doing some SEO on my own site.
The display works rather well. Same style as mine, similar brightness. Debatable how useful the head-up feature is in a Civic with the 2-level dash but can be very handy in other vehicles.
Warning lamps on the head-up display can be useful - if it can talk to your car appropriately.
OBD can be variable - it very much depends on the car how quickly it will let you refresh the data, and the datafeed is rounded to the nearest kph so you do get some funny conversion to mph going on. Covered here if you're interested:
Why doesn't the SpeedView Head up Display use the OBD port?
Not a dealbreaker, and it has the major advantage of being plug and play, but can be a little annoying as a speedo.
Tyre pressures are a disaster though. Those sensors are about 2 cm in size and weigh enough to unbalance your wheel (10g or so). Tyre valves are meant to seal internally, not on the threads, so those replacement caps will leak. That's if they don't get nicked first, or have the batteries go flat.
Tyre temperature is quite a useful tool for setting up a car. You need 3 pyrometers though (inner, middle, outer) and the data logging needs to be fairly live. A single measure of temp/pressure isn't that useful to you - come in from a hot lap and quick check in the pit is just as good.
(I supply a hardwired version of this that shows speed only)
any bit of gloss black plastic in the right place will display the speed on the windscreen at night,wait til night time and place your phone just in front of speedo you will see what i mean.
I have a bit in place all the time so at night in shows on screen pointless I know
You're better with a dark tint film. ;)
Use a 5-10% light transmission, one-way mirror film. A sticker on the screen will/should fail the MOT if its more than 40 mm into the wiper swept area, but tint films are exempt from this requirement. A good old school trick from the sunstrip days: one-way mirror tint for the lettering, limo black over the top of it for the background - gets you black on silver and completely legal! :D
Construction and Use regs will nail you if you do something stupid (you can't obstruct the driver's view of the road ahead) but if you just want to overlap the bit that the wipers wipe slightly then its fine, and meets the MOT rules. :)
The purpose designed displays are over 5,000 nits, so you see them in daylight too, even when looking straight at the sun:
Not that useful with the Civic double-dash, but there are quite a few applications where they're handy. eg - tall bloke in an MX5:
:police: "Oh yes sir, I can tell you exactly how fast I was going. Somewhere between 60 and 120..." :rolleyes:
Or do you mean gloss plastic as a mirror on the top-level of the dash to project the OE speedo up there?
Any chance you could snap a photo of that for us? I'm curious how crisp it is/how bad the ghosting is with the Civic sized digits.
Cheers,
M
