1 - 20 of 45 Posts
K20 addict
Ok so in november I had the whole lot done, new pump, condensor, relay and regas.
Was working fine til now (always had climate on) but now I went to get it Ice cold and its not playing ball. Even the revs don't did anymore.
Surely not needing a regas already??
K20 addict
K20 addict
The air con is murder! Have you changed your relay?
Yep, relay (genuine), condensor and pump in November! Guessing a leak has sprung and low pressure means its not kicking in.
Hopefully something simple like the seals on the pressure switches. Will get it in to an ac place
Wooops I skipped passed the relay part in your original post :worms: I’m going to be doing the same with mine, any idea on the cost of getting it all replaced? It just doesn’t work at all. Zero cold air :(
K20 addict
Completely depends whats gone mate. Ive tallied up ive spent close to 400 all in so far including all those parts, 2 regas and labour.
Pump can be the expensive part, risk second hand or get a new one for like 160 quid. I got mine off a lad doing a turbo conversion for 40 quid so I knew it was still working and he just wanted rid.
Thanks mate. Sorry for hijacking your thread a bit there!
K20 addict
K20 addict
Air con pressure tested and regassed.
Works fine now but clearly a minor leak somewhere so will check for leaks with the dye he's put in now, when it runs out again.
Would've thought it'd be a fairly chunky leak for it to lose its gas since november tho?!
K20 addict
This was the job sheet
K20 addict
Discussion Starter #12
How often do you lot have the AC on? Mine's constantly on 'auto' at 20 deg. Could that be why it's ran out so fast?
i keep mine on constantly
about 18 degrees in summer and 22 ish in winter
i re did mine last year but not because of a leak the high pressure sensor was playing up and it was re gassed when i bought the car nearly 5 years ago
by rights it's a sealed unit ( like your fridge ) and shouldn't need re gassing for quite some time
if it does the refrigerant must be leaking out somewhere
K20 addict
Discussion Starter #14
Must be. Annoyingly can't trace it.....yet. Hopefully the dye will when it empties again
Mine was leaking at the compressor
It would last about a month between regases before stopping again
Had mine nitrogen tested and that's where then leak was from
So far it's been a month and it's still going
Dye was added as well and i check it once a week with glasses and a UV light
K20 addict
Discussion Starter #16
New compressor job?
Yes i had to fit one luckily a mate of mine is a manager at Gsf so i got a denso unit cheap plus £100 for fitting and gas and dye
Clutch pedal guru
To lose most of the refrigerant in 4.5 months isn't a major leak. It's probably a leaky joint or something simple like that.
K20 addict
Discussion Starter #19
And its dead again! No leaks detected but all pressure lost in less than a month. Getting seriously f**ked off with this car now!!
1 - 20 of 45 Posts
