Does anyone know where the air con drain is under the car 9th gen facelift.
I've never had a wet patch under car so want to see if its blocked.
Sent from my SM-G975F using Tapatalk
You would likely have a wet patch inside the car if it was blocked.
Is the air con working?
Yeah air con works fine!
Had car 2 years and never seen a wet patch but when i have the 8th gen i had a wet patch everytime i used it.
Not looked in car for any wet patches mind will have to.
regrets his username
I've found it doesn't happen all the time, as you mentioned it was always there on the 8th gen, but the 9th gen it can just randomly appear when it wants to
Its strange had the car nearly 2 years and never noticed a wet patch under it.
I had it serviced 2 weeks ago too and said A/C was fine and doesn't need re-gassing.
I
I had a similar problem and it was a hole in the cooling pipe. Check if you have liquid on Coolant Reservoir, my was empty.
Enviado do meu EML-L09 através do Tapatalk
