first one I would expect to be the flap motor faulty
can you run actuator tests as this would help diagnose the problem better I'm not sure if the ethos will do this as I have the solus that can do them
the second code looks like a can bus communication code it shouldn't cause any operational problems if it is not running a oem radio that's why its there but either way I wouldn't worry about it and concentrait on the first code if the air con is faulty
