Hi Guys
Just purchased a VTEC 1.8 SE, UK model - so right-hand-drive.
All good, but the air-con smells quite a bit and the air in general smells. I'm guessing the cabin air filter could do with changing, but searching on the net there's lots of videos etc on how to change this but on the left-hand-drive model, which, I would assume is the same on mine but it doesn't seem to be.
Anyone done this before on a UK model?
more torque than the mrs
Hey, anyone replaced their pollen filter themselves? I wanted to have a look at mine to see if it's black enough to need replacing as I had my air con re-gassed at the weekend. I found on a different thread saying it's down in the passenger footwell, behind a panel. I've had a look, and think I've found it, but not certain enough to want to start tugging on it. Can anyone help?
I've attached a picture of what I've found... Is it that tall plastic panel with a horizontal clip at the bottom and a hook like thing at the top (circled)?
Any help appreciated.
remove the panel underneath your glovebox (passenger footwell)its only clips on then you will see from the picture where its located.hope this helps.
sorry no picture i will get one for you.
Speak to dan from coxmotorparts he'll be able to get you a new filter
here##
