Seems my AC is only working intermittingly. I've purchased the new relay, although the old one is working fine.
When you turn on the AC you can hear the relay switch and the 2 fans at the front of the engine switch on. If the AC comes on then you hear an additional noise as the compressor fires up. If the AC fails to come on you don't.
When working the air is cold so I assume it doesn't need regassing.
Suspect problem is the clutch air gap, although can't get to measure it or possibly pressure switch.
Any other idea's?
Seems to be very few AC specialists in Lancashire (unless anyone knows of any), so it seems I'll have to get ripped off at Honda, but would like to go armed with as much info as possible!
Steve
Discussion Starter #2
All working now!
Sent from my HTC One_** using Tapatalk
Hi sorry to hijack this thread however from this evening I am the proud owner of an 07 CTR. The new car (I thought) needed to be regassed which the dealer said he will do for me at a later date (was just so eager to drive it away), but on the way home the AC suddenly started working and was ice cold. It's since stopped so I'm a bit in limbo?
