Hi all,
I have a civic SE 1.8 (2008), i haven't had it for long but since I've had it the locking has been intermittent.
Sometimes when I lock the car either with the fob or with the key all indicators will flash and the red LED will be on the dash signifying the alarm has been armed and the car is locked. This is fine when it works!
More often than this is when i lock the car either with the key or fob, the car will lock as it should but the indicators do not flash and i have no LED on the dash!
It decides when it wants to work and when it doesn't, it doesn't matter how i lock it or distance or length of time i hold the button or how many times i press the button!
Also to top it all off my alarm keeps going off for no reason!!
Do you think the 2 are linked?
Please help?
Have you tried disconnecting the battery for half an hour to reset everything? Make sure keys are out of ignition before disconnecting and before reconnecting the battery.
Thank you for your response.
will try that now.
the problem with alarm has stopped think its due to when locking the car now im not getting any lights flashing or the red LCD on the dash at all?
