1 - 20 of 470 Posts
Hi Guys
I've refrained thus far from posting too much junk as I'm a 7th gen Honda driver and this is of Couse an 8th gen forum.
But alas I feel the time is right to break the seal and discuss some of the things I'm planning in a couple of weeks. Mostly to take advantage of the expertise on the boards, many a knowledgeable member lurks on civinfo - as it home to some quality N/A K builds!
1st up, I feel I have got the car to a good state with the regular bolt-ons, I'm happy with the chassis and most of the important stuff like brakes etc. are good.
TDI-N tuned the car at the start of the year and she’s been running a nice simple motor configuration.
I dont want to boost as a next step, as IMO it takes a little something away from the charm of the K20.
So I did my research and saved some pennies for the following:
Prayoonto Stage 2 cams
Supertech Beehives and Hi-comp valves
I don't know anyone who has installed these on a European car yet, so its gunna be interesting in terms of cam angles, base maps etc.
I also don't know what the optimum compression is going to be for this setup on UK 99ron fuel... the cam specs are 305/300 13.46mm/11.94mm, so I'm hoping 11.3:1 is enough.
I would whole heartedly welcome any advice or ideas and of course would be happy to discuss any details!
very nice cams. Prayoonto makes good stuff.
if i wanted stage 2 cams, i would buy prayoonto.
Some really nice figure there! What mods have you added?
The current engine mods are: Piper header and exhaust (2.5")
Skunk2 intake manifold and Throttle
Plus an Injen CAI with velocity stack
They are manufactured on Brain Crowers new 8620 steel billet cores, so they should be damn tough!
99RON fuel for 11.3:1 seems to be useless. 305/300 13.46/11.94 you won't max the cams with this compression rate. You definatelly need more compression. I'm hitting like 12.5:1. If TODA A3 needs more compression and they are "lighther" 297/13 on intake as far as I remember than this specification needs more than upgraded A3s.
I understand what your saying File, I need to make a quick decision on if I should buy a toda/spoon head gasket! The thing is full duration of the cams and static compression can only tell you so much about the situation.
Overlap between the intake & exhaust opening and ramp times will affect the dynamic compression too.
But I 'm thinking 11.7:1 might be a better CR if it means the power comes in earlier.
I forgot to list the RDX injectors, really rate these for an N/A car, she runs smoother than stock now!
After running the numbers through a spread sheet to work out the dynamic CR, 11.7:1 will be needed to keep the cranking pressure optimal.
so a skinny one of these is on the way
Discussion Starter #14
Had a bit of an issue with worn out valve guides & seals in the head. Waiting for parts from the USA has set me back a couple of weeks.
Ended up with a spoon gasket (purely due to lack of stock, and a better price than Toda). Also some Avid engine mounts to keep the motor still.
The next consideration is to get tuned right away, or run the car on a safe map untill I can get a 3" exhaust made?
Are any of you guys running a 3" header back?
Cockup Specialist
Theres a few 70mm custom single exit cat backs.
CivicRSA, Allagios I think...2 or 3 others maybe.
well said
Reactions: s18fty225
1 - 20 of 470 Posts
