1 - 2 of 2 Posts
#darkside
Hello all
I currently have stock 18s and will be buying some "summer alloys and tyres" shortly.
I know what sort of wheels I ideally want however I need to know the exact spec as to not cause myself issues.
Tyres will be 225/40 r18 AD08s.
As such I will need 18" x 'X'j, ET'X' 5stud Honda fit.
Can you guys fill in the "X"s. I'm looking for a wider stance of around 15mm without the need for spacers (more expense) and without the risk of rubbing.
The car is not lowered however will have FRS.
#MrGrumpy
Hello all
The standard wheels are 7.5J and ET55. If you are keeping 7.5J you will need ET40 for a 15mm wider stance.
If you want to go wider on the alloys such as 8J, you would need ET46.
FYI the Honda fit is 5 x 114.3 PCD.
1 - 2 of 2 Posts
