1 - 14 of 14 Posts
Honda Civic typically uses one of three common tire sizes: 195/65R15, 205/55R16, and 215/45R17. Many Civics use 195/65R15, but there are quite a few higher trim levels that use 205/55R16, so be sure to check your actual tire size that is on your car.
That should be 225/45 R17.
wheels: yes civic mk 10 wheels should be spot fitment for a mk9. pcd, bore, offset are all the same.
tyres: on it's 17" wheels a mk10 has 235/45ZR17. fitment on a 17" wheen on a mk9 would have been 225/45R17 so this is the tyre size you need. that said, you prob won't run into any issues with a tyre thats only 10mm wider but technically its not the "right" size.
Mk10 should have PCD 5x120, so it will not fit mk9. As for the tyre size, not sure if 235 would make any rubbing. Depends how low is you car, and wheel offset.
I'm 99% certain that that info is wrong. (...) A 10G Civic has a PCD of 5x114.3 which is the same as most (if not all) Civics since 2004.
Here's a complete info:
  • both 9th gen and 10th gen have 5 x 114.3
  • both 9th gen and 10th gen Type-R have 5 x 120
Moderator
i think your info is wrong. What is your source? Can you a link or something as to enlighten us?
Please note that the second link clearly states
18" 1FORM EDITION.1 (EDT.1) ALLOY WHEELS
To Fit Your Honda Civic (10th Gen) All Models exc. Type-R (2017 - 2020)
The wheels linked to have a PCD of 114.3mm as do the ones in the first link. The second link thus suggests that the Type-R is not 114.3mm (which supports narimiran's statement.)
Wheel-size.com I find is a great source for OEM wheel data.
Extracts below just to be helpful :)
2015 Civic 5Dr (9G) - 5x114.3
313209
2019 Civc 5Dr (10G) - EUDM - 5x114.3
313211
2015 Civic Type R (9G) - 5x120
313208
2019 Civic Type R (10G) - EUDM - 5x120
313210
Thank you. I guess all turbo type-rs have 5x120 bolt pattern. I think my non turbo had 5x114.
1 - 14 of 14 Posts
