Does anyone know if the alternator terminal set connector have anything inside it more than just plain metal connector ?
Connectoris the number six in this picture:
I had to loose the nut out from it but for some reason the whole bolt snapped
the same time so there is now no place to connect alternator earth wire. I trien to connect it straight to the other end of the terminal connectors place, but it ended up burning the main fuse. After that I did a temporary fix and soldered the connector ring to the terminal connector and changed the main fuse and it worked fine.
But now I'm wondering if the fuse burning happened due to something missing from the line inside the terminal connector or just bad luck.
