Ey up!
I want to add an amplifier to my oem system due to having sat nav and voice control and want to retain it all.
I'd like to avoid cutting wires so what I wanted to do was add a small loom between the oem loom and the radio to allow me to run speaker level inputs off to the amp, and retain all the oem stuff.
So what i think I'd need is a male and female plug, and a selection of wires. But I don't know where I can get these plugs!
Can anyone help, or provide better advice? (Except put an aftermarket in!)
Cheers!!
Lol if I were you mate I would simply cut the wires, solder in extensions then heat shrink it all tidy again. Otherwise your going to have a mass of clips and plugs behind your HU which could easily come undone over a speed bump.
Ive never seen anywhere selling the plugs for the stock HUs, and have spent hours browsing mod sites etc. You could try buying a replacement loom from Honda and cutting them off but it will be costly and I'm not sure you would get a female plug anywhere.
Plus you could use matching wire colours to make it easier.
Ive put in an aftermarket with camera, power to aerial amp and 2 sets of footwell lighting all soldered up for a proper strong connection. Simple enough and will never go wrong.
Sent from my SM-G955F using Tapatalk
Etc..
Thanks for the reply!
I've never known any plugs coming undone, and I've really crammed looms in behind HUs before (Renault Clio with HU, mic, gps antenna and sub! Old vws are good too!) but I've never had one come back because the plug came undone.
I had considered butchering an SOT Lead as this has a male and female plug for oem looms but I've never been good at depinning plugs on cars! But this suggests they are manufactured so I wondered if there was somewhere to get hold of them!
As I said I want to keep the dash standard :) I just hate the lack of any clarity in the sound system!
Yeh I'm with u on the cramming front, my pumpkin android HU came with its own loom plus I had to put in the connects2 harness and DAB kit behind it too. In the end I realised it was physically impossible so butchered the cd draw underneath so I could use it for loom space.
These Hondas are worse than the Ford's and peugeots I've tinkered with in the past, hence the idea to solder everything to prevent having to ever get it all undone and open again.
All I can do is offer you the best of luck in fixing up a home made loom, I don't envy your task but a challenge is good for the soul.
Haha yeah been there!
Well I don't think it's impossible. Having a second look at an SOT lead is pretty much ready made for what I need! I'd just need to take off the speaker wires from the ISO side and run them to the amp. In theory.. in my head.. so probably not I'll make sure I report back if it works lol!
theres a lead which you can buy its an orca convertor. it works with pretty much any vehicle.. I'm opening up my audio system next week and fitting rear camera and subwoofer leads.
